Aller au contenu principal
Modal MD-WORCSS6 Motor Replacement
Ce dont vous avez besoin
  1. Modal MD-WORCSS6 Motor Replacement, Modal MD-WORCSS6 Teardown Guide: étape 1, image 1 de 2 Modal MD-WORCSS6 Motor Replacement, Modal MD-WORCSS6 Teardown Guide: étape 1, image 2 de 2
    • Put on Electrostatic Discharge (ESD) bracelet. Hold the device with the transparent plastic casing on the top.
    • Using the jimmy tool, carefully pry off the black plastic ring.
    • Remove the spring assembly from inside the transparent plastic tube.
  2. Modal MD-WORCSS6 Motor Replacement: étape 2, image 1 de 2 Modal MD-WORCSS6 Motor Replacement: étape 2, image 2 de 2
    • Using a Phillips #1 screwdriver, unscrew each of the four 12.7 mm screws inside and at the bottom of the plastic tube.
    • Take the plastic tube off of the metal casing.
  3. Modal MD-WORCSS6 Motor Replacement: étape 3, image 1 de 2 Modal MD-WORCSS6 Motor Replacement: étape 3, image 2 de 2
    • Place the jimmy tool blade between the button assembly and the metal casing. Gently pry off the button assembly; it should pop out.
    • With the button assembly removed, slide off the metal casing.
  4. Modal MD-WORCSS6 Motor Replacement: étape 4, image 1 de 3 Modal MD-WORCSS6 Motor Replacement: étape 4, image 2 de 3 Modal MD-WORCSS6 Motor Replacement: étape 4, image 3 de 3
    • Unscrew the two 6.4 mm screws in the black plastic body using the Phillips #1 screwdriver.
    • Separate the two halves of the plastic body. Keep the half containing the motor facing up.
  5. Modal MD-WORCSS6 Motor Replacement: étape 5, image 1 de 3 Modal MD-WORCSS6 Motor Replacement: étape 5, image 2 de 3 Modal MD-WORCSS6 Motor Replacement: étape 5, image 3 de 3
    • Carefully peel the tape off far enough to remove the 3 batteries.
  6. Modal MD-WORCSS6 Motor Replacement, Motor: étape 6, image 1 de 3 Modal MD-WORCSS6 Motor Replacement, Motor: étape 6, image 2 de 3 Modal MD-WORCSS6 Motor Replacement, Motor: étape 6, image 3 de 3
    • Slide the circuit board out of its slot.
    • Pull the white plastic neck down and out of the slot. Remove the neck and body spring.
  7. Modal MD-WORCSS6 Motor Replacement: étape 7, image 1 de 1
    • Use wire cutters to cut the wires connected to the bottom of the motor.
    • Remove the motor from the plastic body.
  8. Modal MD-WORCSS6 Motor Replacement: étape 8, image 1 de 1
    • Strip the insulation from the wire up to about half an inch from the end of the exposed wire.
    • Attach a new motor to the device by re-soldering the connections that were cut earlier.
    • Check out our How to Solder and Desolder Connections guide for best practices and soldering tips.
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 1
30 derniers jours : 5
Total : 169
