Introduction
When a faucet starts to leak, it may become difficult to turn on/off and you may experience inconsistent temperature issues. If it is difficult to turn the handle or you notice continuous dripping after shutting off the faucet, it is likely that you will need to replace the cartridge.
This guide will provide you with the necessary steps to replace the Moen one-handle replacement cartridge, Model 1225. To find the specific cartridge type, identify the faucet model by checking the spout, plate, or handle, and visit www.moen.com for product specifications.
Prior to starting this procedure, you will need to locate the main water shutoff valve for your home. If your property is equipped with a curb stop valve, you will need your meter key, also known as a valve key, to proceed with step 1 of this guide.
Ce dont vous avez besoin
Turn off the main water supply by inserting your meter key into the curb stop valve handle and rotating it 180 degrees counterclockwise to the closed position.
If your faucet continues to leak after replacing the cartridge, there may be another underlying issue causing the problem with your plumbing. Inspect the O-rings, seals, and other components of the faucet for any damage and consult professional assistance to resolve the issue.
