Aller au contenu principal
Monster SoundStage S1 Mini Speaker Replacement
Ce dont vous avez besoin
  1. Monster SoundStage S1 Mini Speaker Replacement, Speaker: étape 1, image 1 de 2 Monster SoundStage S1 Mini Speaker Replacement, Speaker: étape 1, image 2 de 2
    • Remove the speaker wires from the motherboard by pinching the plastic tab at the end of the cable and pulling towards you.
  2. Monster SoundStage S1 Mini Speaker Replacement: étape 2, image 1 de 2 Monster SoundStage S1 Mini Speaker Replacement: étape 2, image 2 de 2
    • Unscrew 1.2 cm Torx security screw, holding the silver circle connector, to disconnect the wire from the speakerboard to the motherboard
  3. Monster SoundStage S1 Mini Speaker Replacement: étape 3, image 1 de 1
    • Remove the black putty from the speaker wires at both ends of the speaker board.
  4. Monster SoundStage S1 Mini Speaker Replacement: étape 4, image 1 de 3 Monster SoundStage S1 Mini Speaker Replacement: étape 4, image 2 de 3 Monster SoundStage S1 Mini Speaker Replacement: étape 4, image 3 de 3
    • Solder the black plastic encasing the red and black wires.
  5. Monster SoundStage S1 Mini Speaker Replacement: étape 5, image 1 de 2 Monster SoundStage S1 Mini Speaker Replacement: étape 5, image 2 de 2
    • Remove both the black and red wires with pliers
    • Pliers may stick to speaker because it is magnetic.
  6. Monster SoundStage S1 Mini Speaker Replacement: étape 6, image 1 de 2 Monster SoundStage S1 Mini Speaker Replacement: étape 6, image 2 de 2
    • Tuck wires through the hole where the speaker is located, then gently push the speaker out.
    • The 1.2 cm Torx security screws that stayed in place near the speaker will now fall out.
    • To remove the other speaker repeat steps 3-6
Heather Carrillo
Membre depuis le 09/12/16
412 Réputation
2 tutoriels rédigés
Équipe
CSU Fullerton, Team 2-6, Bruce Fall 2016 Membre de l'équipe CSU Fullerton, Team 2-6, Bruce Fall 2016
CSUF-BRUCE-F16S2G6
4 membres
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 6
30 derniers jours : 14
Total : 499
