Aller au contenu principal
Monster Soundstage S2 Logic Board Replacement
Ce dont vous avez besoin
  1. Monster Soundstage S2 Logic Board Replacement, Speaker Grille: étape 1, image 1 de 2 Monster Soundstage S2 Logic Board Replacement, Speaker Grille: étape 1, image 2 de 2
    • Use a spudger or your fingers to pry off and remove the rubber pad on the bottom of the speaker.
  2. Monster Soundstage S2 Logic Board Replacement: étape 2, image 1 de 3 Monster Soundstage S2 Logic Board Replacement: étape 2, image 2 de 3 Monster Soundstage S2 Logic Board Replacement: étape 2, image 3 de 3
    • Remove the five 10mm screws with a TR 10 screwdriver.
    • Use a spudger to break the remaining adhesive holding the grille to the speaker body.
    • Be sure you don't bend the grille; it is not free from the speaker yet.
  3. Monster Soundstage S2 Logic Board Replacement: étape 3, image 1 de 1
    • Flip speaker around and use a plastic opening tool to remove the top panel from the speaker.
  4. Monster Soundstage S2 Logic Board Replacement: étape 4, image 1 de 3 Monster Soundstage S2 Logic Board Replacement: étape 4, image 2 de 3 Monster Soundstage S2 Logic Board Replacement: étape 4, image 3 de 3
    • Use a plastic opening tool to remove the foam and uncover four more screws.
    • Use a TR 10 screwdriver to remove the five 10mm screws on the top of the speaker.
  5. Monster Soundstage S2 Logic Board Replacement: étape 5, image 1 de 2 Monster Soundstage S2 Logic Board Replacement: étape 5, image 2 de 2
    • Carefully remove the top cover.
    • Be careful not to tear or stress the cable that provides power to the power LED.
  6. Monster Soundstage S2 Logic Board Replacement: étape 6, image 1 de 2 Monster Soundstage S2 Logic Board Replacement: étape 6, image 2 de 2
    • Use a TR 10 screwdriver to remove two of the 10mm screws that secure the speaker grille.
    • Do not attempt to remove the grille just yet.
  7. Monster Soundstage S2 Logic Board Replacement: étape 7, image 1 de 3 Monster Soundstage S2 Logic Board Replacement: étape 7, image 2 de 3 Monster Soundstage S2 Logic Board Replacement: étape 7, image 3 de 3
    • With the top panel removed, use a spudger to remove the display panel.
    • The clips on the display panel are quite fragile. Pry up both edges of the display before attempting removal.
    • Use a TR 10 screwdriver to remove the four final 10mm screws securing the speaker grille.
  8. Monster Soundstage S2 Logic Board Replacement: étape 8, image 1 de 1
    • Remove the front speaker grille.
  9. Monster Soundstage S2 Logic Board Replacement, Front Speakers: étape 9, image 1 de 3 Monster Soundstage S2 Logic Board Replacement, Front Speakers: étape 9, image 2 de 3 Monster Soundstage S2 Logic Board Replacement, Front Speakers: étape 9, image 3 de 3
    • After removing grille, you will see the speakers.
    • Remove the eight 10mm screws that surround the speakers. There will be four around each speaker.
  10. Monster Soundstage S2 Logic Board Replacement: étape 10, image 1 de 2 Monster Soundstage S2 Logic Board Replacement: étape 10, image 2 de 2
    • Carefully lift each speaker from the housing. It may be necessary to break a light adhesive seal.
    • Be aware of the two wires that are connected to each speaker.
    • Set each speaker beside the main housing.
  11. Monster Soundstage S2 Logic Board Replacement: étape 11, image 1 de 3 Monster Soundstage S2 Logic Board Replacement: étape 11, image 2 de 3 Monster Soundstage S2 Logic Board Replacement: étape 11, image 3 de 3
    • Carefully but firmly unplug the two wires from each driver.
    • The front speakers can now be removed.
  12. Monster Soundstage S2 Logic Board Replacement, Front Panel: étape 12, image 1 de 2 Monster Soundstage S2 Logic Board Replacement, Front Panel: étape 12, image 2 de 2
    • Identify the eight screws around the border of the front panel.
    • Using the TR 10 driver, remove the two 8mm screws.
    • Using the TR 10 driver, remove the six 12mm screws.
  13. Monster Soundstage S2 Logic Board Replacement: étape 13, image 1 de 1
    • Use a 5 mm hex driver to extend the TR 10 driver. This allows the driver to access screws with deeper countersinks.
  14. Monster Soundstage S2 Logic Board Replacement: étape 14, image 1 de 2 Monster Soundstage S2 Logic Board Replacement: étape 14, image 2 de 2
    • Identify the remaining four screws in the front panel.
    • Use the extended driver from the previous step to remove the four 12mm TR 10 screws.
  15. Monster Soundstage S2 Logic Board Replacement: étape 15, image 1 de 2 Monster Soundstage S2 Logic Board Replacement: étape 15, image 2 de 2
    • Gently pull the front panel away from the back panel.
    • There are wires that connect the front and back panels. The two sides can be safely folded away from each other and laid flat on the table.
    • Remove the white sound dampening material from the speaker. Note the location of the material and set aside.
  16. Monster Soundstage S2 Logic Board Replacement, Logic Board: étape 16, image 1 de 3 Monster Soundstage S2 Logic Board Replacement, Logic Board: étape 16, image 2 de 3 Monster Soundstage S2 Logic Board Replacement, Logic Board: étape 16, image 3 de 3
    • Unplug the rear white connector from the logic board.
    • Unplug the rear red connector beside the white one.
  17. Monster Soundstage S2 Logic Board Replacement: étape 17, image 1 de 3 Monster Soundstage S2 Logic Board Replacement: étape 17, image 2 de 3 Monster Soundstage S2 Logic Board Replacement: étape 17, image 3 de 3
    • Unplug the front white connector from the logic board.
  18. Monster Soundstage S2 Logic Board Replacement: étape 18, image 1 de 2 Monster Soundstage S2 Logic Board Replacement: étape 18, image 2 de 2
    • Remove the front ribbon cable from the logic board.
    • There is no retention mechanism on this connector.
  19. Monster Soundstage S2 Logic Board Replacement: étape 19, image 1 de 2 Monster Soundstage S2 Logic Board Replacement: étape 19, image 2 de 2
    • Use a plastic opening tool to lift the brown ribbon cable retainer clip.
    • The ribbon cable can now be removed from the logic board.
  20. Monster Soundstage S2 Logic Board Replacement: étape 20, image 1 de 2 Monster Soundstage S2 Logic Board Replacement: étape 20, image 2 de 2
    • Use a TR 10 driver to remove the four 10mm screws that secure the logic board to the front panel.
    • Remove the logic board from the speaker.
3 autres ont terminé cette réparation.
Shaw Hughes
Membre depuis le 01/30/17
831 Réputation
5 tutoriels rédigés
Équipe
Cal Poly, Team 21-5, Maness Winter 2017 Membre de l'équipe Cal Poly, Team 21-5, Maness Winter 2017
CPSU-MANESS-W17S21G5
4 membres
12 tutoriels rédigés
2 commentaires
Monster Soundstage circuit board supplier?
Bill Wishart - Réponse
@shughe11 Monster Soundstage circuit board supplier?
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 21
Total : 753
