Aller au contenu principal
Monster Soundstage S2 Speaker Grille Replacement
Ce dont vous avez besoin
  1. Monster Soundstage S2 Speaker Grille Replacement, Speaker Grille: étape 1, image 1 de 2 Monster Soundstage S2 Speaker Grille Replacement, Speaker Grille: étape 1, image 2 de 2
    • Use a spudger or your fingers to pry off and remove the rubber pad on the bottom of the speaker.
  2. Monster Soundstage S2 Speaker Grille Replacement: étape 2, image 1 de 3 Monster Soundstage S2 Speaker Grille Replacement: étape 2, image 2 de 3 Monster Soundstage S2 Speaker Grille Replacement: étape 2, image 3 de 3
    • Remove the five 10mm screws with a TR 10 screwdriver.
    • Use a spudger to break the remaining adhesive holding the grille to the speaker body.
    • Be sure you don't bend the grille; it is not free from the speaker yet.
  3. Monster Soundstage S2 Speaker Grille Replacement: étape 3, image 1 de 1
    • Flip speaker around and use a plastic opening tool to remove the top panel from the speaker.
  4. Monster Soundstage S2 Speaker Grille Replacement: étape 4, image 1 de 3 Monster Soundstage S2 Speaker Grille Replacement: étape 4, image 2 de 3 Monster Soundstage S2 Speaker Grille Replacement: étape 4, image 3 de 3
    • Use a plastic opening tool to remove the foam and uncover four more screws.
    • Use a TR 10 screwdriver to remove the five 10mm screws on the top of the speaker.
  5. Monster Soundstage S2 Speaker Grille Replacement: étape 5, image 1 de 2 Monster Soundstage S2 Speaker Grille Replacement: étape 5, image 2 de 2
    • Carefully remove the top cover.
    • Be careful not to tear or stress the cable that provides power to the power LED.
  6. Monster Soundstage S2 Speaker Grille Replacement: étape 6, image 1 de 2 Monster Soundstage S2 Speaker Grille Replacement: étape 6, image 2 de 2
    • Use a TR 10 screwdriver to remove two of the 10mm screws that secure the speaker grille.
    • Do not attempt to remove the grille just yet.
  7. Monster Soundstage S2 Speaker Grille Replacement: étape 7, image 1 de 3 Monster Soundstage S2 Speaker Grille Replacement: étape 7, image 2 de 3 Monster Soundstage S2 Speaker Grille Replacement: étape 7, image 3 de 3
    • With the top panel removed, use a spudger to remove the display panel.
    • The clips on the display panel are quite fragile. Pry up both edges of the display before attempting removal.
    • Use a TR 10 screwdriver to remove the four final 10mm screws securing the speaker grille.
  8. Monster Soundstage S2 Speaker Grille Replacement: étape 8, image 1 de 1
    • Remove the front speaker grille.
3 autres ont terminé cette réparation.
Shaw Hughes
Membre depuis le 01/30/17
831 Réputation
5 tutoriels rédigés
Équipe
Cal Poly, Team 21-5, Maness Winter 2017 Membre de l'équipe Cal Poly, Team 21-5, Maness Winter 2017
CPSU-MANESS-W17S21G5
4 membres
12 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 8
Total : 453
