Aller au contenu principal
Montgomery Ward GEN-39500 Subwoofer Replacement
Ce dont vous avez besoin
  1. Montgomery Ward GEN-39500 Subwoofer Replacement, Back Cover: étape 1, image 1 de 1
    • Remove the nine 35 mm Phillips screws securing the back cover of the case.
  2. Montgomery Ward GEN-39500 Subwoofer Replacement: étape 2, image 1 de 1
    • Carefully remove the back cover.
    • Soldered wires connect electronics on the back cover to the internal electronics. Be careful not to break any connections.
  3. Montgomery Ward GEN-39500 Subwoofer Replacement: étape 3, image 1 de 2 Montgomery Ward GEN-39500 Subwoofer Replacement: étape 3, image 2 de 2
    • Unplug the black and yellow wires connecting the power supply unit to the rest of the electronics:
    • This is not necessarily required. This step is to allow the back cover more movement as you work on the inside of the unit.
  4. Montgomery Ward GEN-39500 Subwoofer Replacement, Subwoofer: étape 4, image 1 de 2 Montgomery Ward GEN-39500 Subwoofer Replacement, Subwoofer: étape 4, image 2 de 2
    • Unsolder the wires leading to and from the subwoofer.
  5. Montgomery Ward GEN-39500 Subwoofer Replacement: étape 5, image 1 de 1
    • Unscrew the four 12.5 mm Phillips screws holding the subwoofer in place.
    • One of the screws holds down a metal cable organizer. For better cable organization after reassembly keep track of this organizer.
  6. Montgomery Ward GEN-39500 Subwoofer Replacement: étape 6, image 1 de 1
    • Remove the subwoofer.
    • The process is the same for both sides.
Dustin Platt
Membre depuis le 04/01/15
931 Réputation
6 tutoriels rédigés
Équipe
Cal Poly, Team 12-5, Lancaster Spring 2015 Membre de l'équipe Cal Poly, Team 12-5, Lancaster Spring 2015
CPSU-LANCASTER-S15S12G5
4 membres
13 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 2
Total : 136
