Introduction
The LCD readout on this multimeter develops missing segments in the numbers making them unreadable. Simply removing and cleaning the conducting polymer strip that connects the small LCD screen to the circuit board restores normal LCD function.
Ce dont vous avez besoin
Remove the two screws from the back of the meter to open it.
Remove the black plastic LCD and backlight frame from the top of the circuit board by pushing and releasing the small black plastic pins that protrude through the circuit board. The picture is not in good focus, it shows copper tabs at the top of circuit board and the LCD and polymer strip in the black plastic frame in the background
Replace the polymer strip into the LCD frame making sure it firmly contacts the LCD screen. Then clip the LCD frame back in place on the circuit board by pushing the 4 black plastic pins through the square holes in the circuit board. Make sure the polymer strip makes solid contact with the circuit board.
