Aller au contenu principal
Motorola Buzz ic502 Screen and Speaker Replacement
Ce dont vous avez besoin
  1. Motorola Buzz ic502 Screen and Speaker Replacement, Battery: étape 1, image 1 de 3 Motorola Buzz ic502 Screen and Speaker Replacement, Battery: étape 1, image 2 de 3 Motorola Buzz ic502 Screen and Speaker Replacement, Battery: étape 1, image 3 de 3
    • First flip the phone over.
    • Then find the back release circled in red.
  2. Motorola Buzz ic502 Screen and Speaker Replacement: étape 2, image 1 de 2 Motorola Buzz ic502 Screen and Speaker Replacement: étape 2, image 2 de 2
    • Carefully remove the back using the release.
    • Lift from the bottom!
  3. Motorola Buzz ic502 Screen and Speaker Replacement: étape 3, image 1 de 3 Motorola Buzz ic502 Screen and Speaker Replacement: étape 3, image 2 de 3 Motorola Buzz ic502 Screen and Speaker Replacement: étape 3, image 3 de 3
    • Lift the battery from the right side.
    • After the battery has lifted about a 45 degree angle remove from phone.
  4. Motorola Buzz ic502 Screen and Speaker Replacement, Screen Assembly: étape 4, image 1 de 3 Motorola Buzz ic502 Screen and Speaker Replacement, Screen Assembly: étape 4, image 2 de 3 Motorola Buzz ic502 Screen and Speaker Replacement, Screen Assembly: étape 4, image 3 de 3
    • Remove all six screws
    • The two top screws here
    • The two middle screws here.
    • And the two bottom screws here, they are covered by plastic pieces that first must be removed with the nylon Spudger.
  5. Motorola Buzz ic502 Screen and Speaker Replacement: étape 5, image 1 de 3 Motorola Buzz ic502 Screen and Speaker Replacement: étape 5, image 2 de 3 Motorola Buzz ic502 Screen and Speaker Replacement: étape 5, image 3 de 3
    • then carefully lift the front off the phone.
    • Marked wire will have to be solderd when re-connecting new screen
    • Speakers are connected to the screen here.
To reassemble your device, follow these instructions in reverse order, soldering wire onto new screen.
Austin Quinn
Membre depuis le 10/20/16
401 Réputation
4 tutoriels rédigés
Équipe
UMass Dartmouth, Team 6-6, Martin Fall 2016 Membre de l'équipe UMass Dartmouth, Team 6-6, Martin Fall 2016
UMASSD-MARTIN-F16S6G6
3 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 3
30 derniers jours : 6
Total : 91
