Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Introduction
This repair guide describes how to remove the screen of the Motorola C290.
  1. Flip open your Motorola C290. Remove rubber stoppers located around main screen using a push pin. This reveals four screws.
    • Flip open your Motorola C290.
    • Remove rubber stoppers located around main screen using a push pin.
    • This reveals four screws.
    • Use a Torx T6 Screwdriver to unscrew the four screws.
  2. Use a plastic opening tool to pry open a gap between the top cover and the face of the phone. Slide the plastic opening tool along gap and pry open case.
    • Use a plastic opening tool to pry open a gap between the top cover and the face of the phone.
    • Slide the plastic opening tool along gap and pry open case.
    • Remove top cover.
  3. Unclip circuit attachments located on back of screen circuit board using a Spudger. Unclip circuit attachments located on back of screen circuit board using a Spudger.
    • Unclip circuit attachments located on back of screen circuit board using a Spudger.
  4. Insert the plastic opening tool between the metal screen components and the plastic frame at the corners. Firmly pry the screen components from the frame with a twisting motion You will need to apply a good amount of force as you pry, twisting in a right-to-left motion.
    • Insert the plastic opening tool between the metal screen components and the plastic frame at the corners.
    • Firmly pry the screen components from the frame with a twisting motion
    • You will need to apply a good amount of force as you pry, twisting in a right-to-left motion.
    • Completely remove screen components from frame.
Angelo Ballungay
Membre depuis le 15/04/2010
79 Réputation
4 tutoriels rédigés
Équipe
Cal Poly, Team 24-28, Regan Spring 2010 Membre de l'équipe Cal Poly, Team 24-28, Regan Spring 2010
CPSU-REGAN-S10S24G28
4 membres
6 tutoriels rédigés
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 1,642
