Aller au contenu principal
Motorola California Mobile Phone Motherboard Replacement
Ce dont vous avez besoin
  1. Motorola California Mobile Phone Motherboard Replacement, Motorola California Mobile Phone Teardown: étape 1, image 1 de 1
    • Remove the battery by sliding it down the rails to which it is connected.
  2. Motorola California Mobile Phone Motherboard Replacement: étape 2, image 1 de 1
    • Find a flat head or Phillips head screwdriver.
    • Insert the screwdriver into the holes in the plastic rod connecting the key pad guard to the rear casing.
    • Use the screwdriver to push the rods towards each other until they click out of their locked position.
    • Note: This may require a large amount of force.
  3. Motorola California Mobile Phone Motherboard Replacement: étape 3, image 1 de 1
    • Slide off the antenna guard and locate the four clips on the exterior of the rear casing.
    • Simultaneously push the clips outward while lifting the rear casing and keyguard away from the front casing.
    • Remove the key guard from the rear casing by taking it out of its position.
  4. Motorola California Mobile Phone Motherboard Replacement: étape 4, image 1 de 1
    • Locate and unplug the black component of the antenna from the motherboard.
    • Under the black component should be a blue component. Unscrew this component in order to free the antenna.
  5. Motorola California Mobile Phone Motherboard Replacement: étape 5, image 1 de 1
    • Slide the antenna out of the green tubing and slide the green tubing out of it's corresponding hole on the motherboard.
  6. Motorola California Mobile Phone Motherboard Replacement: étape 6, image 1 de 1
    • Lift the motherboard out of its location in the front casing.
    • Do this slowly and gently so that none of the motherboard's components are damaged.
  7. Motorola California Mobile Phone Motherboard Replacement, Motherboard: étape 7, image 1 de 1
    • With your new motherboard, hold the LCD side of the motherboard face down. Align the four clips on the front casing with the four notches on the motherboard.
    • While doing so, insert the LCD into the compartment in the front casing.
  8. Motorola California Mobile Phone Motherboard Replacement: étape 8, image 1 de 1
    • Press firmly on the motherboard until it is snug inside the casing.
Andrew Lam
Membre depuis le 04/17/12
35 Réputation
4 tutoriels rédigés
Équipe
Cal Poly, Team 9-46, Regan Spring 2012 Membre de l'équipe Cal Poly, Team 9-46, Regan Spring 2012
CPSU-REGAN-S12S9G46
5 membres
8 tutoriels rédigés
Un commentaire
Nice, thanks.
Daniel - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 24
Total : 2,859
