Aller au contenu principal
Motorola Defy Display Assembly Replacement
Ce dont vous avez besoin
  1. Motorola Defy Display Assembly Replacement, Display Assembly: étape 1, image 1 de 2 Motorola Defy Display Assembly Replacement, Display Assembly: étape 1, image 2 de 2
    • Remove the battery cover and the battery itself.
  2. Motorola Defy Display Assembly Replacement: étape 2, image 1 de 2 Motorola Defy Display Assembly Replacement: étape 2, image 2 de 2
    • Using a Torx T5 screwdriver, remove both screws near the camera.
  3. Motorola Defy Display Assembly Replacement: étape 3, image 1 de 1
    • Using the Torx T5 screwdriver, remove all 7 screws around the mobile: 3 on each side + 1 on the botton.
  4. Motorola Defy Display Assembly Replacement: étape 4, image 1 de 3 Motorola Defy Display Assembly Replacement: étape 4, image 2 de 3 Motorola Defy Display Assembly Replacement: étape 4, image 3 de 3
    • Using a plastic opener tool, open the device removing the back cover.
    • Remove the power button and volume button.
  5. Motorola Defy Display Assembly Replacement: étape 5, image 1 de 3 Motorola Defy Display Assembly Replacement: étape 5, image 2 de 3 Motorola Defy Display Assembly Replacement: étape 5, image 3 de 3
    • After opening the device, carefully, using the plastic opening tool, peel off the lcd and digitalizer conectors from the mainboard.
  6. Motorola Defy Display Assembly Replacement: étape 6, image 1 de 1
    • Remove the two yellow rubber protectors near the screws. The rectangular yellow rubber protector might fall off too so put it aside.
  7. Motorola Defy Display Assembly Replacement: étape 7, image 1 de 1
    • Separate the Frame + Digitizer, the LCD and the mainboard.
  8. Motorola Defy Display Assembly Replacement: étape 8, image 1 de 3 Motorola Defy Display Assembly Replacement: étape 8, image 2 de 3 Motorola Defy Display Assembly Replacement: étape 8, image 3 de 3
    • Now, using a plastic opening tool, carefully insert it between the frame and the glass and force it slowly to remove the adhesive. You may also heat it to help.
    • Now, Remove the rest of adhesive from the frame to better apply the new digitizer on it.
    • Follow this backwards to reassemble the mobile.
11 autres ont terminé cette réparation.
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 1
30 derniers jours : 5
Total : 5,746
