Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Introduction
Use this guide to replace your Defy's display assembly. Replacing the display assembly will give you a new front glass panel and digitizer.
Pièces
Aucune pièce spécifiée.
  1. Remove the battery cover and the battery itself. Remove the battery cover and the battery itself.
    • Remove the battery cover and the battery itself.
  2. Using a Torx T5 screwdriver, remove both screws near the camera. Using a Torx T5 screwdriver, remove both screws near the camera.
    • Using a Torx T5 screwdriver, remove both screws near the camera.
  3. Using the Torx T5 screwdriver, remove all 7 screws around the mobile: 3 on each side + 1 on the botton.
    • Using the Torx T5 screwdriver, remove all 7 screws around the mobile: 3 on each side + 1 on the botton.
  4. Le kit d'outils Essentiel
    Les outils les plus utiles dans notre kit le plus compact.
    J'achète
    J'achète
  5. Using a plastic opener tool, open the device removing the back cover. Remove the power button and volume button. Remove the power button and volume button.
    • Using a plastic opener tool, open the device removing the back cover.
    • Remove the power button and volume button.
  6. After opening the device, carefully, using the plastic opening tool, peel off the lcd and digitalizer conectors from the mainboard. After opening the device, carefully, using the plastic opening tool, peel off the lcd and digitalizer conectors from the mainboard. After opening the device, carefully, using the plastic opening tool, peel off the lcd and digitalizer conectors from the mainboard.
    • After opening the device, carefully, using the plastic opening tool, peel off the lcd and digitalizer conectors from the mainboard.
  7. Remove the two yellow rubber protectors near the screws. The rectangular yellow rubber protector might fall off too so put it aside.
    • Remove the two yellow rubber protectors near the screws. The rectangular yellow rubber protector might fall off too so put it aside.
  8. Separate the Frame + Digitizer, the LCD and the mainboard.
    • Separate the Frame + Digitizer, the LCD and the mainboard.
  9. Now, using a plastic opening tool, carefully insert it between the frame and the glass and force it slowly to remove the adhesive. You may also heat it to help. Now, Remove the rest of adhesive from the frame to better apply the new digitizer on it. Follow this backwards to reassemble the mobile.
    • Now, using a plastic opening tool, carefully insert it between the frame and the glass and force it slowly to remove the adhesive. You may also heat it to help.
    • Now, Remove the rest of adhesive from the frame to better apply the new digitizer on it.
    • Follow this backwards to reassemble the mobile.
11 autre(s) ont terminé cette réparation.
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 2
Total : 5,524
