Aller au contenu principal
Motorola Defy Rear Facing Camera Replacement
Ce dont vous avez besoin
  1. Motorola Defy Rear Facing Camera Replacement, Rear Case: étape 1, image 1 de 1
    • Using the screwdriver and the T-5 bit, unscrew the seven 5 mm screws around the outside of the phone.
  2. Motorola Defy Rear Facing Camera Replacement: étape 2, image 1 de 2 Motorola Defy Rear Facing Camera Replacement: étape 2, image 2 de 2
    • Remove the back cover of the phone by sliding the bottom black button to the unlock position and lifting it up.
  3. Motorola Defy Rear Facing Camera Replacement, Battery: étape 3, image 1 de 1
    • Use a plastic opening tool to pry the battery out of the phone.
  4. Motorola Defy Rear Facing Camera Replacement, Midframe: étape 4, image 1 de 1
    • Unscrew the two silver screws located at the top of the back of the phone.
  5. Motorola Defy Rear Facing Camera Replacement: étape 5, image 1 de 1
    • Use a plastic opening tool to gently pry the midframe from the rest of the phone.
  6. Motorola Defy Rear Facing Camera Replacement, Rear Facing Camera: étape 6, image 1 de 2 Motorola Defy Rear Facing Camera Replacement, Rear Facing Camera: étape 6, image 2 de 2
    • Start to pry around the bottom of the camera module with the metal spudger and replace with the new camera module.
    • Be careful of the pins that are connected to the camera module on the bottom.
Morgan Roark
Membre depuis le 10/08/14
325 Réputation
3 tutoriels rédigés
Équipe
USF Tampa, Team 14-2, Leahy Fall 2014 Membre de l'équipe USF Tampa, Team 14-2, Leahy Fall 2014
USFT-LEAHY-F14S14G2
4 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 11
Total : 406
