Aller au contenu principal
Motorola Defy XT Logic Board Replacement
Ce dont vous avez besoin
  1. Motorola Defy XT Logic Board Replacement, Logic Board: étape 1, image 1 de 1
    • Wedge the opening tool in-between the back cover and the body of the phone in the opening denoted by the arrow.
  2. Motorola Defy XT Logic Board Replacement: étape 2, image 1 de 1
    • Once wedged in the opening, slide the opening tool around the side of the phone and remove the back cover, setting it aside.
  3. Motorola Defy XT Logic Board Replacement: étape 3, image 1 de 1
    • Insert the opening tool between the battery and the battery holder and wedge the battery out.
  4. Motorola Defy XT Logic Board Replacement: étape 4, image 1 de 1
    • Open the plastic cover with your finger to expose the SD card.
    • Use the opening tool to grab the edge of the SD card and pull it straight out.
  5. Motorola Defy XT Logic Board Replacement: étape 5, image 1 de 1
    • Remove the six 6mm T4 screws with the T4 torque driver.
  6. Motorola Defy XT Logic Board Replacement: étape 6, image 1 de 1
    • Pop out the volume button with the plastic opening tool.
  7. Motorola Defy XT Logic Board Replacement: étape 7, image 1 de 2 Motorola Defy XT Logic Board Replacement: étape 7, image 2 de 2
    • Wedge the plastic opening tool in-between the plastic layer and the front cover.
    • Do not completely separate the two pieces to avoid damaging the ribbon cable inside.
  8. Motorola Defy XT Logic Board Replacement: étape 8, image 1 de 1
    • Carefully separate the bottom piece from the top plastic piece.
    • Disconnect the ribbon cable connecting the display to the logic board by firmly pulling the cable straight outward.
    • The screen can now be removed.
  9. Motorola Defy XT Logic Board Replacement: étape 9, image 1 de 1
    • Separate the logic board and the display cover from the back cover and orient the logic board so the camera faces toward you.
    • Disconnect the back cover by wedging the plastic opening tool in between the motherboard and the connector and prying outward.
  10. Motorola Defy XT Logic Board Replacement: étape 10, image 1 de 1
    • Flip the logic board and display cover over so the camera faces away from you.
    • Bend the two halves of the device away from you to pry the final ribbon connector off the logic board.
    • The ribbon connector is bonded to the logic board with adhesive, simply pull it to break the glue bond.
2 autres ont terminé cette réparation.
No Name
Membre depuis le 04/21/13
25 Réputation
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 2
30 derniers jours : 2
Total : 1,339
