Aller au contenu principal
Motorola Droid 4 Motherboard Replacement
Ce dont vous avez besoin
  1. Motorola Droid 4 Motherboard Replacement, Removing Rear Panel: étape 1, image 1 de 3 Motorola Droid 4 Motherboard Replacement, Removing Rear Panel: étape 1, image 2 de 3 Motorola Droid 4 Motherboard Replacement, Removing Rear Panel: étape 1, image 3 de 3
    • Insert the rear cover removal tool, or a paper clip, in the hole near the back camera lens.
    • Slide the cover down to remove.
  2. Motorola Droid 4 Motherboard Replacement, Battery: étape 2, image 1 de 1
    • Remove the sticker on the rear compartment to reveal the battery.
    • Hold the battery with your thumb while removing the sticker or you might end up ripping the battery out of the phone, damaging the flex cable.
  3. Motorola Droid 4 Motherboard Replacement: étape 3, image 1 de 2 Motorola Droid 4 Motherboard Replacement: étape 3, image 2 de 2
    Outil utilisé dans cette étape :
    T5 Torx Screwdriver
    $5.49
    J'achète
    • Use the T5 Torx Screwdriver to remove both 2.5 mm screws from the battery cable.
    • Use the Spudger to unstick the battery.
    • It's difficult to remove the battery without a pry tool like the spudger because of the strong adhesive. If you try removing it with just your fingers, the battery may bend.
  4. Motorola Droid 4 Motherboard Replacement, Camera Cover Removal: étape 4, image 1 de 3 Motorola Droid 4 Motherboard Replacement, Camera Cover Removal: étape 4, image 2 de 3 Motorola Droid 4 Motherboard Replacement, Camera Cover Removal: étape 4, image 3 de 3
    • Using the blue plastic opening tool, pry off the thin plastic camera cover.
    • The plastic cover is fragile, so proceed carefully.
  5. Motorola Droid 4 Motherboard Replacement, Remove Screws: étape 5, image 1 de 2 Motorola Droid 4 Motherboard Replacement, Remove Screws: étape 5, image 2 de 2
    • Remove the four screws, indicated by the red circles, with the screwdriver and T5 Torx bit.
    • The screws are philips 2.5mm. One screw is a different color (silver) from the others (black).
  6. Motorola Droid 4 Motherboard Replacement, Remove Bezel: étape 6, image 1 de 3 Motorola Droid 4 Motherboard Replacement, Remove Bezel: étape 6, image 2 de 3 Motorola Droid 4 Motherboard Replacement, Remove Bezel: étape 6, image 3 de 3
    • Insert the spudger between the rear bezel and the main housing.
    • The bezel is fragile, so proceed carefully.
    • Slide the spudger around all sides of the phone to separate the bezel from the housing.
    • Pry the bezel free.
    • Be careful of the adhesive that holds the bezel to the main housing. Prying too hard may damage your phone.
  7. Motorola Droid 4 Motherboard Replacement, Removing screws: étape 7, image 1 de 2 Motorola Droid 4 Motherboard Replacement, Removing screws: étape 7, image 2 de 2
    • Remove the 12 screws holding the housing in place using a T5 Torx screwdriver.
    • Follow the red circles, indicated in the picture, to locate the screws.
    • The 12 screws are (silver) philips 2.5mm
  8. Motorola Droid 4 Motherboard Replacement, Separation of the Housing from the Motherboard: étape 8, image 1 de 3 Motorola Droid 4 Motherboard Replacement, Separation of the Housing from the Motherboard: étape 8, image 2 de 3 Motorola Droid 4 Motherboard Replacement, Separation of the Housing from the Motherboard: étape 8, image 3 de 3
    • Separate the housing from the motherboard.
    • Be careful while separating the housing. The power and volume buttons are easily separated from the housing and can be damaged.
  9. Motorola Droid 4 Motherboard Replacement, Motherboard: étape 9, image 1 de 2 Motorola Droid 4 Motherboard Replacement, Motherboard: étape 9, image 2 de 2
    • The Motherboard is the brain of the phone, handle with care.
    • Using the spudger, separate the motherboard from the keyboard frame.
    • Tilt the motherboard upward from the side of the charger connection as shown in the picture.
  10. Motorola Droid 4 Motherboard Replacement, Disconnecting the Motherboard: étape 10, image 1 de 2 Motorola Droid 4 Motherboard Replacement, Disconnecting the Motherboard: étape 10, image 2 de 2
    • Using the spudger, gently disconnect the two motherboard connections.
    • Once the motherboard is separated from the phone place it in a safe place.
Javier
Membre depuis le 09/29/14
530 Réputation
4 tutoriels rédigés
Équipe
USF Tampa, Team 5-1, Mcgee Fall 2014 Membre de l'équipe USF Tampa, Team 5-1, Mcgee Fall 2014
USFT-MCGEE-F14S5G1
5 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 4
Total : 941
