Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Pièces & Outils
Introduction
The SIM card stores important information on your phone. You should handle it with care when you are using this guide.
You will need to remove several torx head screws. Make sure to use the correct type.
Pièces
Aucune pièce spécifiée.
  1. Insert the rear cover removal tool, or a paper clip, in the hole near the back camera lens. Slide the cover down to remove. Slide the cover down to remove.
    • Insert the rear cover removal tool, or a paper clip, in the hole near the back camera lens.
    • Slide the cover down to remove.
  2. Using tweezers or your finger, lift the rubber SIM card cover to expose the card itself. Using tweezers or your finger, lift the rubber SIM card cover to expose the card itself. Using tweezers or your finger, lift the rubber SIM card cover to expose the card itself.
    • Using tweezers or your finger, lift the rubber SIM card cover to expose the card itself.
  3. Kits pour Nintendo Switch
    Une solution rapide pour reprendre le jeu
    Acheter un kit pour Switch
  4. While holding the cover open, use your finger to press and slide out the SIM card. When reinserting the SIM card, make sure the SIM card is oriented in the correct direction, according to the illustration on the device, and that the metal contact area of the card is facing down. When reinserting the SIM card, make sure the SIM card is oriented in the correct direction, according to the illustration on the device, and that the metal contact area of the card is facing down.
    • While holding the cover open, use your finger to press and slide out the SIM card.
    • When reinserting the SIM card, make sure the SIM card is oriented in the correct direction, according to the illustration on the device, and that the metal contact area of the card is facing down.
  5. Follow the same steps in the opposite order to install the new SIM card. Make sure the SIM card is oriented in the correct direction, according to the illustration on the device, and that the metal contact area of the card is facing down. Make sure the SIM card is oriented in the correct direction, according to the illustration on the device, and that the metal contact area of the card is facing down.
    • Follow the same steps in the opposite order to install the new SIM card.
    • Make sure the SIM card is oriented in the correct direction, according to the illustration on the device, and that the metal contact area of the card is facing down.
Ligne d'arrivée
Javier
Membre depuis le 29/09/2014
530 Réputation
4 tutoriels rédigés
Équipe
USF Tampa, Team 5-1, Mcgee Fall 2014 Membre de l'équipe USF Tampa, Team 5-1, Mcgee Fall 2014
USFT-MCGEE-F14S5G1
5 membres
5 tutoriels rédigés
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 0
7 derniers jours : 10
30 derniers jours : 29
Total : 2,679
