Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Pièces & Outils
Introduction
How to replace the rear camera on the Motorola Droid MAXX 2 if the back camera isn't working properly.
Pièces
Aucune pièce spécifiée.
  1. Insert a small pointed object into the hole on the sim card tray to eject the tray from the phone.
    • Insert a small pointed object into the hole on the sim card tray to eject the tray from the phone.
  2. Pull the sim card tray up out of the phone
    • Pull the sim card tray up out of the phone
  3. Wedge your thumb into the indent located on the bottom left corner of the back cover and pull up to remove the back cover. Wedge your thumb into the indent located on the bottom left corner of the back cover and pull up to remove the back cover.
    • Wedge your thumb into the indent located on the bottom left corner of the back cover and pull up to remove the back cover.
  4. Manta Precision Bit Set
    112 embouts pour toute réparation.
    Upgrade Your Toolbox
  5. Remove the seventeen 3.2mm Torx T4 screws from the mid-frame.
    • Remove the seventeen 3.2mm Torx T4 screws from the mid-frame.
    • These may be T3 screws. If you are having trouble unscrewing these, stop and try a T3 bit.
  6. Pull the mid-frame off of the phone.
    • Pull the mid-frame off of the phone.
    • Keep track of the on/off and volume buttons when you take the phone apart because they are likely to fall out when the halves are separated.
  7. Remove the static tape covering the two connectors. Use a spudger to disconnect the battery cables from the motherboard. If battery has adhesive, use heat gun for one to two minutes to loosen it. Be careful of the points outlined in red when prying it up. Use guitar picks or a spudger to gently lift the battery and separate the adhesive.
    • Remove the static tape covering the two connectors.
    • Use a spudger to disconnect the battery cables from the motherboard.
    • If battery has adhesive, use heat gun for one to two minutes to loosen it. Be careful of the points outlined in red when prying it up. Use guitar picks or a spudger to gently lift the battery and separate the adhesive.
  8. Remove the disconnected battery from the phone.
    • Remove the disconnected battery from the phone.
  9. Peel up orange adhesive that covers the ZIF connector.
    • Peel up orange adhesive that covers the ZIF connector.
  10. Use a spudger to lift up the black tab on the ZIF connector.
    • Use a spudger to lift up the black tab on the ZIF connector.
    • Remove the camera.
Burke Seggerman
Membre depuis le 18/03/2018
656 Réputation
5 tutoriels rédigés
Équipe
Baylor, Team S3-G4, Williams Spring 2018 Membre de l'équipe Baylor, Team S3-G4, Williams Spring 2018
BU-WILLIAMS-S18S3G4
3 membres
6 tutoriels rédigés
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 5
Total : 204
