Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Introduction
Use this guide to replace the glass on the rear of your Motorola Droid RAZR M.
Outils
Aucun outil spécifié.
Pièces
  1. Shattered!
    • Shattered!
  2. Glass won't just pop off. It is held by a very sticky tape. Carefully scraping the tape with the glass pieces off and vacuum the area after to prevent a clean surface.
    • Glass won't just pop off. It is held by a very sticky tape. Carefully scraping the tape with the glass pieces off and vacuum the area after to prevent a clean surface.
    • Be aware of jumping tiny glass pieces during process. Protect your eyes and area around you. They can get stuck in skin too.
  3. SAUTEZ LA MISE À NIVEAU
    Économisez en réparant avec un kit tout-en-un.
    Fix Kits pour iPhone
  4. To replace the part you first need to attach the sticky tape. It comes in the correct outlines. Take the inner parts out to keep those areas free (Camera, Flash, Loudspeaker and a hole).
    • To replace the part you first need to attach the sticky tape. It comes in the correct outlines. Take the inner parts out to keep those areas free (Camera, Flash, Loudspeaker and a hole).
    • Before you take the film off practice the attaching. You will have it hard to reposition after its attached. Same goes with the lens itself, practice before the tape film is off. Once you feel safe to go, peel the film off and go for it!
  5. Done :-)
    • Done :-)
Ligne d'arrivée
3 autre(s) ont terminé cette réparation.
Alex R
Membre depuis le 27/09/2013
188 Réputation
1 tutoriel rédigé
This is not a razr maxx !!!!
Fausto Lebron - Réponse
This isn't a Razr Maxx. The back doesn't have glass on a razr maxx.
Alex Tucker - Réponse
This is Droid razr m . not maxx
Qais Afridi - Réponse
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 1
7 derniers jours : 1
30 derniers jours : 1
Total : 7,231
