Aller au contenu principal
Motorola Droid RAZR Maxx Antenna/Headphone Jack Replacement
Ce dont vous avez besoin
  1. Motorola Droid RAZR Maxx Antenna/Headphone Jack Replacement, Antenna/Headphone Jack: étape 1, image 1 de 2 Motorola Droid RAZR Maxx Antenna/Headphone Jack Replacement, Antenna/Headphone Jack: étape 1, image 2 de 2
    • Remove the SIM card.
    • Remove the microSD card.
    • Insert the plastic opening tool between the back cover and the front piece of the case, freeing the plastic clips between the phone.
    • Do this along the back right side of the phone cover until you reach the top.
  2. Motorola Droid RAZR Maxx Antenna/Headphone Jack Replacement: étape 2, image 1 de 2 Motorola Droid RAZR Maxx Antenna/Headphone Jack Replacement: étape 2, image 2 de 2
    • Use the plastic opening tool to carefully work your way around the top of the phone, freeing the plastic clips.
    • Be cautious when using the tool around the top of the device because the plastic case is very thin and could easily be cracked or snapped.
    • After this continue using the tool and pry down the remaining side and the bottom of the phone.
  3. Motorola Droid RAZR Maxx Antenna/Headphone Jack Replacement: étape 3, image 1 de 3 Motorola Droid RAZR Maxx Antenna/Headphone Jack Replacement: étape 3, image 2 de 3 Motorola Droid RAZR Maxx Antenna/Headphone Jack Replacement: étape 3, image 3 de 3
    • With all the plastic clips released, pull away the back cover from the phone to remove it.
    • The back cover is attached to the battery with a large amount of adhesive. Some force may be required to pull the back cover from the phone.
    • The back cover is very durable and will not break from some bending or pulling.
  4. Motorola Droid RAZR Maxx Antenna/Headphone Jack Replacement: étape 4, image 1 de 1
    • Looking at the top rectangular hump where the camera is located, you will now use the plastic opening tool to remove the camera cover.
    • With the plastic opening tool, apply pressure into any surrounding crease of the camera cover to remove it.
  5. Motorola Droid RAZR Maxx Antenna/Headphone Jack Replacement: étape 5, image 1 de 3 Motorola Droid RAZR Maxx Antenna/Headphone Jack Replacement: étape 5, image 2 de 3 Motorola Droid RAZR Maxx Antenna/Headphone Jack Replacement: étape 5, image 3 de 3
    • Using the T5 and T4 bit pieces, remove the silver screws located around the rear case of the phone.
    • Remove the three 6.7 mm silver T4 screws that are located at the top of the phone.
    • Remove the five 4.0 mm silver T5 screws that are located near the middle of the phone.
  6. Motorola Droid RAZR Maxx Antenna/Headphone Jack Replacement: étape 6, image 1 de 1
    • Using the T4 bit piece remove the three black 4.5 mm screws that are located at the bottom of the phone.
  7. Motorola Droid RAZR Maxx Antenna/Headphone Jack Replacement: étape 7, image 1 de 3 Motorola Droid RAZR Maxx Antenna/Headphone Jack Replacement: étape 7, image 2 de 3 Motorola Droid RAZR Maxx Antenna/Headphone Jack Replacement: étape 7, image 3 de 3
    • Insert the plastic opening tool between the rear case and motherboard assembly.
    • Using the plastic opening tool, carefully work your way around the phone, freeing the plastic clips.
    • Carefully pull the rear case off the motherboard assembly.
  8. Motorola Droid RAZR Maxx Antenna/Headphone Jack Replacement: étape 8, image 1 de 2 Motorola Droid RAZR Maxx Antenna/Headphone Jack Replacement: étape 8, image 2 de 2
    • Use the tip of the spudger, lift the red silicone cover off the battery terminal screws.
    • Remove the two 3.3mm T5 Torx battery terminal screws.
    • Grab the red battery removal tab and pull the battery out.
    • There might be some adhesive between the battery and motherboard assembly.
  9. Motorola Droid RAZR Maxx Antenna/Headphone Jack Replacement: étape 9, image 1 de 2 Motorola Droid RAZR Maxx Antenna/Headphone Jack Replacement: étape 9, image 2 de 2
    • Using the T5 bit pieces, remove the silver screws located around the metal chassis.
    • Remove the three 3.5 mm silver T5 screws that are located near the middle of the phone.
  10. Motorola Droid RAZR Maxx Antenna/Headphone Jack Replacement: étape 10, image 1 de 3 Motorola Droid RAZR Maxx Antenna/Headphone Jack Replacement: étape 10, image 2 de 3 Motorola Droid RAZR Maxx Antenna/Headphone Jack Replacement: étape 10, image 3 de 3
    • Using the plastic opening tool gently lift the microphone out of its resting place.
    • Using the plastic opening tool gently lift the front-facing camera out of its resting place.
    • Be careful not to pull and disconnect these devices.
  11. Motorola Droid RAZR Maxx Antenna/Headphone Jack Replacement: étape 11, image 1 de 3 Motorola Droid RAZR Maxx Antenna/Headphone Jack Replacement: étape 11, image 2 de 3 Motorola Droid RAZR Maxx Antenna/Headphone Jack Replacement: étape 11, image 3 de 3
    • There are four clips that must be released at the top and sides of the phone before the Antenna/Headphone Jack can come completely off.
    • Using the plastic opening tool, carefully pry the Antenna/Headphone Jack piece off the motherboard assembly.
2 autres ont terminé cette réparation.
Nick Kraese
Membre depuis le 10/08/14
657 Réputation
2 tutoriels rédigés
Équipe
USF Tampa, Team 14-6, Leahy Fall 2014 Membre de l'équipe USF Tampa, Team 14-6, Leahy Fall 2014
USFT-LEAHY-F14S14G6
4 membres
10 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 1,539
