Aller au contenu principal
Motorola Droid RAZR Maxx Back Cover Replacement
Ce dont vous avez besoin
  1. Motorola Droid RAZR Maxx Back Cover Replacement, Taking off the Back Cover: étape 1, image 1 de 2 Motorola Droid RAZR Maxx Back Cover Replacement, Taking off the Back Cover: étape 1, image 2 de 2
    • Remove the SIM card.
    • Remove the microSD card.
    • Insert the plastic opening tool between the back cover and the front piece of the case, freeing the plastic clips between the phone.
    • Do this along the back right side of the phone cover until you reach the top.
  2. Motorola Droid RAZR Maxx Back Cover Replacement: étape 2, image 1 de 2 Motorola Droid RAZR Maxx Back Cover Replacement: étape 2, image 2 de 2
    • Use the plastic opening tool to carefully work your way around the top of the phone, freeing the plastic clips.
    • Be cautious when using the tool around the top of the device because the plastic case is very thin and could easily be cracked or snapped.
    • Continue using the tool and pry down the remaining side and the bottom of the phone.
  3. Motorola Droid RAZR Maxx Back Cover Replacement: étape 3, image 1 de 3 Motorola Droid RAZR Maxx Back Cover Replacement: étape 3, image 2 de 3 Motorola Droid RAZR Maxx Back Cover Replacement: étape 3, image 3 de 3
    • With all the plastic clips released, pull away the back cover from the phone to remove it.
    • The back cover is attached to the battery with a large amount of adhesive. Some force may be required to pull the back cover from the phone.
    • The back cover is very durable and will not break from some bending or pulling.
4 autres ont terminé cette réparation.
sean crocker
Membre depuis le 10/08/14
341 Réputation
1 tutoriel rédigé
Équipe
USF Tampa, Team 14-6, Leahy Fall 2014 Membre de l'équipe USF Tampa, Team 14-6, Leahy Fall 2014
USFT-LEAHY-F14S14G6
4 membres
10 tutoriels rédigés
2 commentaires
Ok so I have the cover off of the back of my Droid Razr Maxx HD? But where is it that I can purchase the new back cover? I figured you guys would have at least a hyper link to somewhere I could buy it? Instead of just having instructions on how to remove the backing? Thanks Very Respectfully, Joey K
sailorjt1985 - Réponse
I have same problem. Need new back cover.
TheShellex - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 2,730
