Aller au contenu principal
Motorola Droid RAZR Motherboard Assembly Replacement
Conditions préalables uniquement
Ce tutoriel est uniquement destiné à être utilisé comme prérequis d'autres tutoriels. Il ne se suffit pas à lui-même.
Ce dont vous avez besoin
  1. Motorola Droid RAZR Motherboard Assembly Replacement, Back Cover: étape 1, image 1 de 2 Motorola Droid RAZR Motherboard Assembly Replacement, Back Cover: étape 1, image 2 de 2
    • Insert a plastic opening tool between the back cover and rear case at the lower left edge of the back cover.
    • Pry the back cover up with the plastic opening tool to free the plastic clips.
    • Continue prying along the left edge of the back cover towards the top of the phone.
  2. Motorola Droid RAZR Motherboard Assembly Replacement: étape 2, image 1 de 3 Motorola Droid RAZR Motherboard Assembly Replacement: étape 2, image 2 de 3 Motorola Droid RAZR Motherboard Assembly Replacement: étape 2, image 3 de 3
    • Work the plastic opening tool across the top of the back case to free the plastic clips.
    • The top edge of the back case is very thin. Pry carefully to avoid cracking or snapping it.
    • Continue prying down the right side of the back cover to free the remaining clips.
  3. Motorola Droid RAZR Motherboard Assembly Replacement: étape 3, image 1 de 3 Motorola Droid RAZR Motherboard Assembly Replacement: étape 3, image 2 de 3 Motorola Droid RAZR Motherboard Assembly Replacement: étape 3, image 3 de 3
    • Pull the back cover away from the phone to remove it.
    • The back cover is attached to the battery with a generous amount of adhesive, so you may have to use quite a bit of force to separate the two pieces.
    • The battery must remain in the phone and not come off with the back cover or you will break the power lead.
    • Since the back cover is made of Kevlar, it can handle a fair amount of twisting and tugging without breaking.
  4. Motorola Droid RAZR Motherboard Assembly Replacement, Battery: étape 4, image 1 de 2 Motorola Droid RAZR Motherboard Assembly Replacement, Battery: étape 4, image 2 de 2
    • Use the tip of a spudger to lift up the red silicone cover over the battery terminal screws and remove it.
  5. Motorola Droid RAZR Motherboard Assembly Replacement: étape 5, image 1 de 3 Motorola Droid RAZR Motherboard Assembly Replacement: étape 5, image 2 de 3 Motorola Droid RAZR Motherboard Assembly Replacement: étape 5, image 3 de 3
    • Remove the two 3.3 mm T5 Torx battery terminal screws.
    • Grab the blue battery removal tab and lift the battery out to remove it.
    • There is quite a bit of adhesive securing the battery to the motherboard. Work slowly to avoid deforming the battery.
    • Your phone will have a number of metal EMI shields on the motherboard, rather than the bare ICs seen here.
  6. Motorola Droid RAZR Motherboard Assembly Replacement, Camera Cover: étape 6, image 1 de 2 Motorola Droid RAZR Motherboard Assembly Replacement, Camera Cover: étape 6, image 2 de 2
    • Use a heat gun or hair dryer to soften the adhesive underneath the camera cover.
    • The following steps were performed without the use of a heat gun. Notice that the camera cover cracks very easily if you do not heat the adhesive that holds it in place.
    • Gently pry up the bottom edge of the camera cover with a plastic opening tool.
    • Carefully slide the plastic opening tool across the bottom edge to free it from the adhesive.
    • Continue to use the heat gun as needed to soften the adhesive as you remove the camera cover.
  7. Motorola Droid RAZR Motherboard Assembly Replacement: étape 7, image 1 de 3 Motorola Droid RAZR Motherboard Assembly Replacement: étape 7, image 2 de 3 Motorola Droid RAZR Motherboard Assembly Replacement: étape 7, image 3 de 3
    • Insert the plastic opening tool underneath the top edge of the camera cover.
    • Gently pry the camera cover up as you slide the plastic opening tool across the top edge to free it from the adhesive.
    • Remove the camera cover.
  8. Motorola Droid RAZR Motherboard Assembly Replacement, Rear Case: étape 8, image 1 de 1
    • Remove the six screws securing the rear case to the rest of the phone:
    • three 6.7 mm silver T3 Torx screws at the top,
    • four 4.0 mm gold T3 Torx screws in the middle,
    • and three 4.5 mm black T5 Torx screws at the bottom.
  9. Motorola Droid RAZR Motherboard Assembly Replacement: étape 9, image 1 de 3 Motorola Droid RAZR Motherboard Assembly Replacement: étape 9, image 2 de 3 Motorola Droid RAZR Motherboard Assembly Replacement: étape 9, image 3 de 3
    • Insert a plastic opening tool between the rear case and the motherboard assembly.
    • Work your way down the side of the phone and gently pry the rear case up.
    • Separate the rear case from the motherboard assembly.
  10. Motorola Droid RAZR Motherboard Assembly Replacement, Motherboard Assembly: étape 10, image 1 de 2 Motorola Droid RAZR Motherboard Assembly Replacement, Motherboard Assembly: étape 10, image 2 de 2
    • Remove the three 2.5 mm T3 Torx screws securing the metal chassis to the motherboard.
    • Remove the metal chassis from the motherboard assembly.
  11. Motorola Droid RAZR Motherboard Assembly Replacement: étape 11, image 1 de 2 Motorola Droid RAZR Motherboard Assembly Replacement: étape 11, image 2 de 2
    • Use the flat end of a spudger to remove the two red silicone microphone covers at the top and bottom of the motherboard.
  12. Motorola Droid RAZR Motherboard Assembly Replacement: étape 12, image 1 de 1
    • There is a small metal shield that covers the display assembly cable connectors on the motherboard. This shield is held in place by a few small clips that attach to the surrounding EMI shields.
    • Use the tip of a spudger to gently bend the clips out of shape and remove the shield.
  13. Motorola Droid RAZR Motherboard Assembly Replacement: étape 13, image 1 de 3 Motorola Droid RAZR Motherboard Assembly Replacement: étape 13, image 2 de 3 Motorola Droid RAZR Motherboard Assembly Replacement: étape 13, image 3 de 3
    • Use the flat end of a spudger to pry the three display cable connectors off their sockets on the motherboard.
  14. Motorola Droid RAZR Motherboard Assembly Replacement: étape 14, image 1 de 2 Motorola Droid RAZR Motherboard Assembly Replacement: étape 14, image 2 de 2
    • There are a number of small black plastic clips on the display assembly that hold the motherboard in place.
    • Release the securing clips with a plastic opening tool.
  15. Motorola Droid RAZR Motherboard Assembly Replacement: étape 15, image 1 de 3 Motorola Droid RAZR Motherboard Assembly Replacement: étape 15, image 2 de 3 Motorola Droid RAZR Motherboard Assembly Replacement: étape 15, image 3 de 3
    • Use a heat gun or hair dryer to soften the adhesive strip around the perimeter of the motherboard.
    • Pry the edges of the motherboard up from the display assembly with a plastic opening tool.
    • Remove the motherboard assembly.
David Hodson
Membre depuis le 04/13/10
150 493 Réputation
127 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 582
