Aller au contenu principal
Motorola Droid Turbo Front Facing Camera Replacement
Ce dont vous avez besoin
  1. Motorola Droid Turbo Front Facing Camera Replacement, Rear Case: étape 1, image 1 de 1
    • Prepare an iOpener and lay it over the rear case to soften the adhesive on securing the rear case to the phone.
  2. Motorola Droid Turbo Front Facing Camera Replacement: étape 2, image 1 de 2 Motorola Droid Turbo Front Facing Camera Replacement: étape 2, image 2 de 2
    • Use a plastic opening tool to pry the rear case off of the rest of the device.
    • Remove the rear case.
    • The wireless charging coil may try to stick to the rear case, so make sure to remove it from the case before fully separating the rear case from the rest of the device.
  3. Motorola Droid Turbo Front Facing Camera Replacement, Midframe: étape 3, image 1 de 1
    • Remove the midframe bezel.
  4. Motorola Droid Turbo Front Facing Camera Replacement: étape 4, image 1 de 1
    • Remove the four Torx T5 screws securing the midframe plate.
  5. Motorola Droid Turbo Front Facing Camera Replacement: étape 5, image 1 de 1
    • Remove the midframe.
  6. Motorola Droid Turbo Front Facing Camera Replacement, Front Facing Camera: étape 6, image 1 de 2 Motorola Droid Turbo Front Facing Camera Replacement, Front Facing Camera: étape 6, image 2 de 2
    • Use the pointed end of a spudger to flip up the black retaining flap of the front facing camera's ZIF connector.
  7. Motorola Droid Turbo Front Facing Camera Replacement: étape 7, image 1 de 2 Motorola Droid Turbo Front Facing Camera Replacement: étape 7, image 2 de 2
    • Remove the front-facing camera.
Luis Arangu
Membre depuis le 01/20/16
1 127 Réputation
3 tutoriels rédigés
Équipe
USF Tampa, Team 15-5, Remmell Spring 2016 Membre de l'équipe USF Tampa, Team 15-5, Remmell Spring 2016
USFT-REMMELL-S16S15G5
3 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 10
Total : 1,727
