Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Introduction
Use this guide to replace the motherboard on your Motorola Droid Turbo.
  1. Prepare an iOpener and lay it over the rear case to soften the adhesive on securing the rear case to the phone.
    • Prepare an iOpener and lay it over the rear case to soften the adhesive on securing the rear case to the phone.
  2. Use a plastic opening tool to pry the rear case off of the rest of the device. Remove the rear case.
    • Use a plastic opening tool to pry the rear case off of the rest of the device.
    • Remove the rear case.
    • The wireless charging coil may try to stick to the rear case, so make sure to remove it from the case before fully separating the rear case from the rest of the device.
  3. Remove the midframe bezel.
    • Remove the midframe bezel.
  4. Remove the four Torx T5 screws securing the midframe plate.
    • Remove the four Torx T5 screws securing the midframe plate.
  5. Remove the midframe.
    • Remove the midframe.
  6. Use the point of a spudger to pop up the battery connector. Use the point of a spudger to pop up the battery connector.
    • Use the point of a spudger to pop up the battery connector.
  7. OUVRIR TOUS LES ONGLETS
    Kits de mise à jour de RAM pour Mac
    Voir les kits
    Assez de RAM
    pour ouvrir tous les onglets
    Voir les kits
  8. Fold the wireless charging coil away from the battery. Fold the wireless charging coil away from the battery.
    • Fold the wireless charging coil away from the battery.
  9. Use a spudger to gently pry the battery up from the rest of the device. The battery is secured with some moderate adhesive, so some force may be necessary.
    • Use a spudger to gently pry the battery up from the rest of the device.
    • The battery is secured with some moderate adhesive, so some force may be necessary.
  10. Remove the four Torx T5 screws securing the lower antenna board to the motherboard.
    • Remove the four Torx T5 screws securing the lower antenna board to the motherboard.
  11. Remove the lower antenna board. Remove the lower antenna board.
    • Remove the lower antenna board.
  12. Remove the SIM  card holder/volume button rocker. Remove the SIM  card holder/volume button rocker.
    • Remove the SIM card holder/volume button rocker.
  13. Carefully lift up the motherboard to expose the display connector. Carefully lift up the motherboard to expose the display connector.
    • Carefully lift up the motherboard to expose the display connector.
  14. Use the flat end of a spudger to flip up the retaining flap on the display ZIF connector. Pull the display ribbon cable free of the connector.
    • Use the flat end of a spudger to flip up the retaining flap on the display ZIF connector.
    • Pull the display ribbon cable free of the connector.
    • At this point, the motherboard has been removed from the phone. The following steps will detail removing the wireless charging coil, as well as both cameras so that they can be transferred to the replacement motherboard.
  15. Use the flat end of a spudger to disconnect the wireless charging coil connector from the motherboard. Use the flat end of a spudger to disconnect the wireless charging coil connector from the motherboard.
    • Use the flat end of a spudger to disconnect the wireless charging coil connector from the motherboard.
  16. Use the flat end of a spudger to flip up the black retaining flap on the front-facing camera ZIF connector. Use the flat end of a spudger to flip up the black retaining flap on the front-facing camera ZIF connector.
    • Use the flat end of a spudger to flip up the black retaining flap on the front-facing camera ZIF connector.
  17. Remove the front-facing camera. Remove the front-facing camera.
    • Remove the front-facing camera.
  18. Use the flat end of a spudger to flip up the tan retaining flap on the rear-facing camera ZIF connector. Use the flat end of a spudger to flip up the tan retaining flap on the rear-facing camera ZIF connector.
    • Use the flat end of a spudger to flip up the tan retaining flap on the rear-facing camera ZIF connector.
  19. Remove the rear-facing camera. Remove the rear-facing camera. Remove the rear-facing camera.
    • Remove the rear-facing camera.
6 autre(s) ont terminé cette réparation.
Luis Arangu
Membre depuis le 20/01/2016
1 091 Réputation
3 tutoriels rédigés
Équipe
USF Tampa, Team 15-5, Remmell Spring 2016 Membre de l'équipe USF Tampa, Team 15-5, Remmell Spring 2016
USFT-REMMELL-S16S15G5
3 membres
6 tutoriels rédigés
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 1
7 derniers jours : 4
30 derniers jours : 36
Total : 6,585
