Aller au contenu principal
Motorola Droid X Battery Replacement
  1. Motorola Droid X Battery Replacement, Battery: étape 1, image 1 de 2 Motorola Droid X Battery Replacement, Battery: étape 1, image 2 de 2
    • Locate the power button at the top of the phone. Depress power button for 2 seconds until a menu appears.
  2. Motorola Droid X Battery Replacement: étape 2, image 1 de 2 Motorola Droid X Battery Replacement: étape 2, image 2 de 2
    • Once the menu appears, select the "power off" option. Wait until the phone is completely off.
  3. Motorola Droid X Battery Replacement: étape 3, image 1 de 2 Motorola Droid X Battery Replacement: étape 3, image 2 de 2
    • Place thumb on the back cover, and push down towards the bottom of the device. Once the cover releases, pull it away from the phone and set it aside.
  4. Motorola Droid X Battery Replacement: étape 4, image 1 de 2 Motorola Droid X Battery Replacement: étape 4, image 2 de 2
    • Find the yellow pull tab located in the upper left corner. Pull the tab until the battery dislodges. Grab the battery by the raised edge, and remove it from the case.
  5. Motorola Droid X Battery Replacement: étape 5, image 1 de 1
    • The battery has been successfully removed.
5 autres ont terminé cette réparation.
Alfred Rosen
Membre depuis le 10/04/12
117 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 18-40, Regan Fall 2012 Membre de l'équipe Cal Poly, Team 18-40, Regan Fall 2012
CPSU-REGAN-F12S18G40
3 membres
10 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 1
30 derniers jours : 5
Total : 3,947
