Pièces
Aucune pièce nécessaire.
  1. Objective: remove the rear case from the Motorola Droid X phone.
    • Objective: remove the rear case from the Motorola Droid X phone.
      • This is what the Motorola Droid X looks like before disassembly. In the front, there is a large LCD touch screen.
  2. INSTRUCTION: Turn the phone over so that the back faces up.
    • INSTRUCTION: Turn the phone over so that the back faces up.
    • Objective: remove the battery casing plate.
      • The case plate has a push and slide mechanism.
    • INSTRUCTION 1: Push on the upper side of the casing located under the camera lens.
    • INSTRUCTION 2: Slide down the battery case plate.
    • INSTRUCTION: Insert your finger tips into the edges of the opening and pull the casing off.
    • Objective: remove the battery from the battery compartment.
    • INSTRUCTION: Grab the red tab that says "Battery Release" and slowly lift it up. This will remove the battery.
    • Objective: remove two small black screws from the back of the phone.
      • These two (2) screws help hold the phone together. They need to be removed by a Phillips Hex 2mm screwdriver,
    • INSTRUCTION: Remove two black screws from the back of the phone.
    • Objective: remove the two plastic pieces in front of the phone - they cover the remaining screws.
      • The two plastic pieces are clipped onto the phone as covers. They are located at the top and the bottom of the phone.
    • INSTRUCTION: Flip the phone over to the front side.
    • INSTRUCTION: Use the iFixit tool as a crowbar to pry the top plastic cover piece off of the phone. It will pop off.
    • INSTRUCTION: Use the iFixit tool as a crowbar to pry the bottom plastic piece off the phone.
    • Objective: remove four white screws from the corners of the screen.
      • These four (4) screws help hold the phone together. Use a Phillips Hex 2mm screwdriver
    • INSTRUCTION: remove the 2 white screws from the upper corners of the screen.
    • INSTRUCTION: remove the 2 white screws from the lower corners of the screen.
    • Objective: remove the rear case from the phone in order to provide access to inside the phone.
      • The phone is now held together by the casing alone. You need to pop the two halves apart.
    • INSTRUCTION: Use the iFixit tool like a crowbar to pry apart the front and rear halves of the casing. They will pop apart.
    • Now you are ready to access the internal circuits of the phone.
2 autre(s) ont terminé cette réparation.
Anna
Membre depuis le 08/10/2012
28 Réputation
1 tutoriel rédigé
Équipe
Ohio State, Team 1-1, Voss Fall 2012 Membre de l'équipe Ohio State, Team 1-1, Voss Fall 2012
OSU-VOSS-F12S1G1
3 membres
1 tutoriel rédigé
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 677
