Aller au contenu principal
Motorola Entice w766 Motherboard Replacement
Ce dont vous avez besoin
  1. Motorola Entice w766 Motherboard Replacement, Battery: étape 1, image 1 de 1
    • Slide the tab off the back of the device.
  2. Motorola Entice w766 Motherboard Replacement: étape 2, image 1 de 1
    • Use the tab located at the top of the battery to release the battery.
  3. Motorola Entice w766 Motherboard Replacement, Motherboard: étape 3, image 1 de 3 Motorola Entice w766 Motherboard Replacement, Motherboard: étape 3, image 2 de 3 Motorola Entice w766 Motherboard Replacement, Motherboard: étape 3, image 3 de 3
    • The six screws need to be taken out with any conventional screw driver tool.
    • You will have to unscrew the six 5.31 mm Star Head #5 screws with the appropriate six star bit.
    • There should be six screws removed from the casing after completion.
  4. Motorola Entice w766 Motherboard Replacement: étape 4, image 1 de 3 Motorola Entice w766 Motherboard Replacement: étape 4, image 2 de 3 Motorola Entice w766 Motherboard Replacement: étape 4, image 3 de 3
    • First you will need to locate the lip on the left side of the device.
    • Next you will insert the black spudger firmly into side opening to loosen the casing.
    • Using the blue pry tool gently remove the black and silver casing.
    • The motherboard should then be exposed after removal.
  5. Motorola Entice w766 Motherboard Replacement: étape 5, image 1 de 3 Motorola Entice w766 Motherboard Replacement: étape 5, image 2 de 3 Motorola Entice w766 Motherboard Replacement: étape 5, image 3 de 3
    Outil utilisé dans cette étape :
    J'achète
    • Remove the flex cable with a pair of tweezers.
    • Be gentle with the flex cable as not to break the connecting wire.
    • Now use a spudger or pry tool to place firmly under the motherboard.
    • After creating clearance with the spudging device grab and remove the motherboard with a clamping tool or hand.
    • Look at the motherboard for scorches or loose pieces which could indicate damage.
    • Refer to the troubleshooting page for further advice to replace the motherboard.
Aalan Miranda
Membre depuis le 09/29/16
210 Réputation
2 tutoriels rédigés
Équipe
IUPUI-Harley-F16S2G4 Membre de l'équipe IUPUI-Harley-F16S2G4
Community
4 membres
2 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 1
30 derniers jours : 9
Total : 221
