Introduction
This guide is a step by step process that allows you to replace your old or damaged flex cable with a new one.
Ce dont vous avez besoin
Push down on the silver tab located at the top center of the back of the Motorola K1m cellphone.
Remove the battery with your fingers by pulling the battery from the top corners labeled "Pull Here" located on the left and right side of the top of the battery.
Remove the battery.
Outil utilisé dans cette étape :Spudger$3.99
To begin detaching the battery dock, unscrew the 4 black screws on each corner of the phone with the T5 Torx Screwdriver.
Lift up the battery dock where the hinges are located. Carefully insert the T5 Torx Screwdriver in between the battery dock and the back plate of the battery. (See the picture to locate the hinges)
Remove the battery dock by popping it up with The Spudger.
Remove the small silver screw located where the top of the back of the phone.
