Aller au contenu principal
Motorola Krzr K1m keyboard repalcement
Ce dont vous avez besoin
  1. Motorola Krzr K1m keyboard repalcement, Keypad: étape 1, image 1 de 2 Motorola Krzr K1m keyboard repalcement, Keypad: étape 1, image 2 de 2
    • Remove the battery with your fingers by pulling the battery from the top corners labeled "Pull Here" located on the left and right side of the top of the battery.
    • Remove the battery.
  2. Motorola Krzr K1m keyboard repalcement: étape 2, image 1 de 3 Motorola Krzr K1m keyboard repalcement: étape 2, image 2 de 3 Motorola Krzr K1m keyboard repalcement: étape 2, image 3 de 3
    Outil utilisé dans cette étape :
    Spudger
    $3.99
    J'achète
    • To begin detaching the battery dock, unscrew the 4 black screws on each corner of the phone with the T5 Torx Screwdriver.
    • Lift up the battery dock where the hinges are located. Carefully insert the T5 Torx Screwdriver in between the battery dock and the back plate of the battery. (See the picture to locate the hinges)
    • Remove the battery dock by popping it up with The Spudger.
  3. Motorola Krzr K1m keyboard repalcement: étape 3, image 1 de 3 Motorola Krzr K1m keyboard repalcement: étape 3, image 2 de 3 Motorola Krzr K1m keyboard repalcement: étape 3, image 3 de 3
    J'achète
    • To remove the chip board, first unplug the flex cable from the logic board with tweezers.
    • Lift up the logic board from the bottom flip with your fingers.
    • Remove the logic board.
  4. Motorola Krzr K1m keyboard repalcement: étape 4, image 1 de 2 Motorola Krzr K1m keyboard repalcement: étape 4, image 2 de 2
    • Gently pop off the keypad with your fingers.
    • Once the keypad is removed, follow all of the steps in reverse order to replace the old keypad with the new keypad.
Jennifer Hudiono
Membre depuis le 01/13/10
42 Réputation
4 tutoriels rédigés
Équipe
Cal Poly, Team 11-1, Forte Winter 2010 Membre de l'équipe Cal Poly, Team 11-1, Forte Winter 2010
CPSU-FORTE-W10S11G1
5 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 4
Total : 4,423
