Introduction
To start, you will need to remove the bottom case of the lapdock. Then you will need to unscrew the left speaker of the lapdock in order to unfasten the motherboard in later steps. Then there will be two screws that you will need to remove in order to free the motherboard from the lapdock. Be sure that all connections to the lapdock components are unplugged before removing the motherboard.
Ce dont vous avez besoin
To take off the Keyboard there are three tabs at the top of the Keyboard in the locations shown in the picture that you must press and unclip. They are located behind each of the keys that are removed.
Remove the two 2mm long phillips head screws from the left speaker and move it away from the motherboard.
