Aller au contenu principal
Motorola MBP667CONNECT Circuit Board Replacement
Ce dont vous avez besoin
  1. Motorola MBP667CONNECT Circuit Board Replacement, Circuit Board: étape 1, image 1 de 3 Motorola MBP667CONNECT Circuit Board Replacement, Circuit Board: étape 1, image 2 de 3 Motorola MBP667CONNECT Circuit Board Replacement, Circuit Board: étape 1, image 3 de 3
    • Remove the two 5 mm Phillips #1 screws on the back of the camera.
    • Use a nylon spudger to remove the casing.
  2. Motorola MBP667CONNECT Circuit Board Replacement: étape 2, image 1 de 3 Motorola MBP667CONNECT Circuit Board Replacement: étape 2, image 2 de 3 Motorola MBP667CONNECT Circuit Board Replacement: étape 2, image 3 de 3
    • Remove the brackets by the speaker on the front side of the camera using the metal spudger.
    • Continue to use the metal spudger to carefully disconnect remaining brackets from casing.
    • Remove the two 5mm Phillips #1 screws on the backside of the camera.
  3. Motorola MBP667CONNECT Circuit Board Replacement: étape 3, image 1 de 3 Motorola MBP667CONNECT Circuit Board Replacement: étape 3, image 2 de 3 Motorola MBP667CONNECT Circuit Board Replacement: étape 3, image 3 de 3
    • Use the nylon spudger to remove the circuit board from the plastic casing for the backside of the camera.
    • Remove the two 5 mm Phillips #1 screws on the black circle receiver housing.
    • Now that the black circle is detached, use a nylon spudger to remove the white plastic circle from the casing.
  4. Motorola MBP667CONNECT Circuit Board Replacement: étape 4, image 1 de 2 Motorola MBP667CONNECT Circuit Board Replacement: étape 4, image 2 de 2
    • You will now be able to carefully pull the receiver wire through the gap in the casing.
Jordan Webb
Membre depuis le 01/16/19
109 Réputation
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 11
Total : 389
