Introduction
In the case of damage or a non-functioning camera on the baby monitor, this guide will show users how to disassemble their camera in order to replace the circuit board.
Ce dont vous avez besoin
Remove the two 5 mm Phillips #1 screws on the back of the camera.
Use a nylon spudger to remove the casing.
Use the nylon spudger to remove the circuit board from the plastic casing for the backside of the camera.
Remove the two 5 mm Phillips #1 screws on the black circle receiver housing.
Now that the black circle is detached, use a nylon spudger to remove the white plastic circle from the casing.
