Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Motorola Moto 360 Case Locking Fastener Replacement
Ce dont vous avez besoin
  1. Motorola Moto 360 Case Locking Fastener Replacement, Wrist Strap: étape 1, image 1 de 1
    Outil utilisé dans cette étape :
    • Locate the spring-loaded pin that attaches the wrist strap to the watch.
    • There is a tiny groove on the end of the pin. This is where you will place the tweezers.
  2. Motorola Moto 360 Case Locking Fastener Replacement: étape 2, image 1 de 1
    • Take care not to lose the spring-loaded pin when removing the strap.
    • Use the tweezers to compress the spring-loaded pin so the strap can be removed.
  3. Motorola Moto 360 Case Locking Fastener Replacement: étape 3, image 1 de 2 Motorola Moto 360 Case Locking Fastener Replacement: étape 3, image 2 de 2
    • Pull the wristband away from the watch face.
  4. Motorola Moto 360 Case Locking Fastener Replacement, Case Locking Fasteners: étape 4, image 1 de 1
    • Locate the rectangular end of the fastener inside the wrist strap mounting pocket.
  5. Motorola Moto 360 Case Locking Fastener Replacement: étape 5, image 1 de 2 Motorola Moto 360 Case Locking Fastener Replacement: étape 5, image 2 de 2
    • Push the point of the pin in behind the fastener and pry it out. There is a notch near the end of the fastener which will engage the pin. Once the end pops out, the fastener will slide out of the slot easliy. Repeat to remove all four of them.
    • That's it. Now the two halves of the watch can be easily separated by just pulling gently with your fingers.
18 autres ont terminé cette réparation.
Chris K.
Membre depuis le 02/27/17
661 Réputation
1 tutoriel rédigé
9 commentaires de tutoriel
I lost my fasteners... where can I buy more?
thiagopimenta - Réponse Partager
One misleading thing about this guide: pictures show the back cover taken off, while in fact you don't need to do this -- just take out the fasteners.
Дмитрий Трубин (Dmitry Trubin) - Réponse Partager
Absolutely correct, you don't need to heat or take the back off. I will say though that getting those clips out was damnably fiddly for me.
Ethan Duffy - Partager
ou peut acheter Case Locking Fastener Replacement pour moto360 mon bracelet tien pas
svp chez besoin case locking fastener
abellegarde - Réponse Partager
don't remove the back!
follow this video for removing the locking pins.
I did it, so can you!
https://www.youtube.com/watch?v=Jw3n5qbG...
davidlanchart - Réponse Partager
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 11
30 derniers jours : 57
Total : 8,218
