Aller au contenu principal
Introduction
The battery on this phone is covered by a plastic casing and will require the removal of some screws and plastic parts.
If your battery is swollen, take appropriate precautions.
  1. Turn off the device before beginning the battery replacement. To remove the back cover, start at one corner and stick the plastic opening tool under the cover and pry it away from the phone.
    • Turn off the device before beginning the battery replacement.
    • To remove the back cover, start at one corner and stick the plastic opening tool under the cover and pry it away from the phone.
    • With the plastic opening tool, pry all the way around the phone while lifting up on the cover.
    • You should hear a snapping sound at each corner.
  2. Unscrew all 14- 4mm screws located on the back part of the phone using a T4 Torx bit.
    • Unscrew all 14- 4mm screws located on the back part of the phone using a T4 Torx bit.
    • Working on a magnet board is recommended as the screws are small and can be easily misplaced.
  3. Using the same plastic opening tool as in step 1, once again pry up on the edges of the plastic back cover.
    • Using the same plastic opening tool as in step 1, once again pry up on the edges of the plastic back cover.
    • Be sure that all of the screws are out before lifting the cover. The plastic backing is fragile, and it may break.
  4. Gently lift the back plate away, exposing the motherboard. The battery will be stuck to the back of the cover, so be careful when lifting it off.
    • Gently lift the back plate away, exposing the motherboard. The battery will be stuck to the back of the cover, so be careful when lifting it off.
    • Do not touch the connections to the battery in the red square on the picture.
  5. Gently pull up on the red and black power cable to lift the connector out of the motherboard.
    • Gently pull up on the red and black power cable to lift the connector out of the motherboard.
    • Move the battery and cover away from the motherboard.
  6. Lift gently on the battery using the metal spudger tool.
    • Lift gently on the battery using the metal spudger tool.
    • The battery is stuck to the plastic case with double sided tape. You should hear the battery peeling away from the cover as you are pulling on it.
    • Obtain a new battery and place it into the plastic casing using double sided tape or whatever is provided with the new battery.
35 autres ont terminé cette réparation.
Alex Craig
Membre depuis le 11/03/2015
2 530 Réputation
5 tutoriels rédigés
Équipe
Colorado Springs, Team 5-7, Panko Spring 2015 Membre de l'équipe Colorado Springs, Team 5-7, Panko Spring 2015
UCCS-PANKO-S15S5G7
2 membres
5 tutoriels rédigés
another quite superb guide from ifixit ....
I'm not surprised either as the guides on here are far and away the best available online.
keep up the good work contributors!
carol - Réponse
is it possible to fit Moto 2 gen battery into Moto 1 gen phone ?
Clement Santhosh - Réponse
This worked very well for me, many thanks!
Tony Franks - Réponse
which battery type or brand should we purchase????????
hridaya123.praja - Réponse
Excellent, clear instructions!
Gerald Griffin - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 5
7 derniers jours : 70
30 derniers jours : 291
Total : 68,329
