Aller au contenu principal
Motorola Moto E4 Plus Charging Board Replacement
Ce dont vous avez besoin
  1. Motorola Moto E4 Plus Charging Board Replacement, Remove the back cover: étape 1, image 1 de 3 Motorola Moto E4 Plus Charging Board Replacement, Remove the back cover: étape 1, image 2 de 3 Motorola Moto E4 Plus Charging Board Replacement, Remove the back cover: étape 1, image 3 de 3
    • Power off your phone before beginning disassembly.
    • Insert the edge of the spudger into the notch on the bottom right corner of the phone.
    • Twist the spudger to start releasing the back cover from the phone.
    • Slide the spudger along the bottom edge to separate the back cover from the phone.
  2. Motorola Moto E4 Plus Charging Board Replacement: étape 2, image 1 de 2 Motorola Moto E4 Plus Charging Board Replacement: étape 2, image 2 de 2
    • Lift the phone unit out of the back cover.
  3. Motorola Moto E4 Plus Charging Board Replacement, Midframe: étape 3, image 1 de 1
    • Remove the eighteen 3.3 mm Phillips screws securing the midframe assembly.
  4. Motorola Moto E4 Plus Charging Board Replacement: étape 4, image 1 de 2 Motorola Moto E4 Plus Charging Board Replacement: étape 4, image 2 de 2
    • Remove the charging board cover.
  5. Motorola Moto E4 Plus Charging Board Replacement: étape 5, image 1 de 3 Motorola Moto E4 Plus Charging Board Replacement: étape 5, image 2 de 3 Motorola Moto E4 Plus Charging Board Replacement: étape 5, image 3 de 3
    • Remove the battery cover.
  6. Motorola Moto E4 Plus Charging Board Replacement: étape 6, image 1 de 2 Motorola Moto E4 Plus Charging Board Replacement: étape 6, image 2 de 2
    • Insert an opening pick underneath the bottom left corner of the motherboard cover.
    • Slide the opening pick between the cover and the second SIM tray to release the plastic clip.
  7. Motorola Moto E4 Plus Charging Board Replacement: étape 7, image 1 de 2 Motorola Moto E4 Plus Charging Board Replacement: étape 7, image 2 de 2
    • Insert an opening pick underneath the bottom right corner of the motherboard cover.
    • Use the opening pick to pry up the motherboard cover.
  8. Motorola Moto E4 Plus Charging Board Replacement: étape 8, image 1 de 2 Motorola Moto E4 Plus Charging Board Replacement: étape 8, image 2 de 2
    • Remove the motherboard cover.
  9. Motorola Moto E4 Plus Charging Board Replacement, Battery Disconnect: étape 9, image 1 de 2 Motorola Moto E4 Plus Charging Board Replacement, Battery Disconnect: étape 9, image 2 de 2
    • Use the edge of a spudger to pry up and disconnect the battery flex cable from the motherboard.
  10. Motorola Moto E4 Plus Charging Board Replacement, Charging Board: étape 10, image 1 de 1
    • Remove the single 2.9 mm Phillips screw holding the charging board to the frame.
  11. Motorola Moto E4 Plus Charging Board Replacement: étape 11, image 1 de 2 Motorola Moto E4 Plus Charging Board Replacement: étape 11, image 2 de 2
    • Use a pair of tweezers to pry up and disconnect the antenna cable.
  12. Motorola Moto E4 Plus Charging Board Replacement: étape 12, image 1 de 2 Motorola Moto E4 Plus Charging Board Replacement: étape 12, image 2 de 2
    • Use the edge of a spudger to pry up and disconnect the interconnect flex cable.
  13. Motorola Moto E4 Plus Charging Board Replacement: étape 13, image 1 de 2 Motorola Moto E4 Plus Charging Board Replacement: étape 13, image 2 de 2
    • Use the edge of a spudger to pry up and disconnect the fingerprint sensor flex cable.
  14. Motorola Moto E4 Plus Charging Board Replacement: étape 14, image 1 de 2 Motorola Moto E4 Plus Charging Board Replacement: étape 14, image 2 de 2
    • Insert the tip of a spudger underneath the bottom edge of the charging board and pry upwards.
    • Remove the charging board.
    • Before reassembly check your new part for any components that might need to be transferred from the old one (e.g. microphone rubber gasket).
2 autres ont terminé cette réparation.
Dominik Schnabelrauch
Membre depuis le 11/23/16
201 012 Réputation
682 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
136 membres
16 560 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 5
30 derniers jours : 16
Total : 2,042
