Aller au contenu principal
Motorola Moto E4 Plus Rear Camera Replacement
Ce dont vous avez besoin
  1. Motorola Moto E4 Plus Rear Camera Replacement, Remove the back cover: étape 1, image 1 de 3 Motorola Moto E4 Plus Rear Camera Replacement, Remove the back cover: étape 1, image 2 de 3 Motorola Moto E4 Plus Rear Camera Replacement, Remove the back cover: étape 1, image 3 de 3
    • Power off your phone before beginning disassembly.
    • Insert the edge of the spudger into the notch on the bottom right corner of the phone.
    • Twist the spudger to start releasing the back cover from the phone.
    • Slide the spudger along the bottom edge to separate the back cover from the phone.
  2. Motorola Moto E4 Plus Rear Camera Replacement: étape 2, image 1 de 2 Motorola Moto E4 Plus Rear Camera Replacement: étape 2, image 2 de 2
    • Lift the phone unit out of the back cover.
  3. Motorola Moto E4 Plus Rear Camera Replacement, Midframe: étape 3, image 1 de 1
    • Remove the eighteen 3.3 mm Phillips screws securing the midframe assembly.
  4. Motorola Moto E4 Plus Rear Camera Replacement: étape 4, image 1 de 2 Motorola Moto E4 Plus Rear Camera Replacement: étape 4, image 2 de 2
    • Remove the charging board cover.
  5. Motorola Moto E4 Plus Rear Camera Replacement: étape 5, image 1 de 3 Motorola Moto E4 Plus Rear Camera Replacement: étape 5, image 2 de 3 Motorola Moto E4 Plus Rear Camera Replacement: étape 5, image 3 de 3
    • Remove the battery cover.
    Hoe kom ik aan een nieuwe cover of waar is die te koop.
    Antoinet - Réponse
  6. Motorola Moto E4 Plus Rear Camera Replacement: étape 6, image 1 de 2 Motorola Moto E4 Plus Rear Camera Replacement: étape 6, image 2 de 2
    • Insert an opening pick underneath the bottom left corner of the motherboard cover.
    • Slide the opening pick between the cover and the second SIM tray to release the plastic clip.
  7. Motorola Moto E4 Plus Rear Camera Replacement: étape 7, image 1 de 2 Motorola Moto E4 Plus Rear Camera Replacement: étape 7, image 2 de 2
    • Insert an opening pick underneath the bottom right corner of the motherboard cover.
    • Use the opening pick to pry up the motherboard cover.
  8. Motorola Moto E4 Plus Rear Camera Replacement: étape 8, image 1 de 2 Motorola Moto E4 Plus Rear Camera Replacement: étape 8, image 2 de 2
    • Remove the motherboard cover.
  9. Motorola Moto E4 Plus Rear Camera Replacement, Battery Disconnect: étape 9, image 1 de 2 Motorola Moto E4 Plus Rear Camera Replacement, Battery Disconnect: étape 9, image 2 de 2
    • Use the edge of a spudger to pry up and disconnect the battery flex cable from the motherboard.
  10. Motorola Moto E4 Plus Rear Camera Replacement, Rear Camera: étape 10, image 1 de 2 Motorola Moto E4 Plus Rear Camera Replacement, Rear Camera: étape 10, image 2 de 2
    • Use a pair of tweezers to peel up the copper tape that covers the rear camera flex connector.
    • Fold the copper tape out of the way.
  11. Motorola Moto E4 Plus Rear Camera Replacement: étape 11, image 1 de 2 Motorola Moto E4 Plus Rear Camera Replacement: étape 11, image 2 de 2
    • Use the flat end of a spudger to pry up and disconnect the rear camera flex cable.
  12. Motorola Moto E4 Plus Rear Camera Replacement: étape 12, image 1 de 1
    • Carefully remove the rear camera with a pair of tweezers.
If possible, turn on your phone and test your repair before reassembly.
5 autres ont terminé cette réparation.
Dominik Schnabelrauch
Membre depuis le 11/23/16
202 691 Réputation
682 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
135 membres
16 731 tutoriels rédigés
Un commentaire
I want Moto e 4 + camera
Mubbu N - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 1
30 derniers jours : 3
Total : 1,544
