Aller au contenu principal
Motorola Moto E4 Plus Vibration Motor Replacement
Ce dont vous avez besoin
  1. Motorola Moto E4 Plus Vibration Motor Replacement, Remove the back cover: étape 1, image 1 de 3 Motorola Moto E4 Plus Vibration Motor Replacement, Remove the back cover: étape 1, image 2 de 3 Motorola Moto E4 Plus Vibration Motor Replacement, Remove the back cover: étape 1, image 3 de 3
    • Power off your phone before beginning disassembly.
    • Insert the edge of the spudger into the notch on the bottom right corner of the phone.
    • Twist the spudger to start releasing the back cover from the phone.
    • Slide the spudger along the bottom edge to separate the back cover from the phone.
  2. Motorola Moto E4 Plus Vibration Motor Replacement: étape 2, image 1 de 2 Motorola Moto E4 Plus Vibration Motor Replacement: étape 2, image 2 de 2
    • Lift the phone unit out of the back cover.
  3. Motorola Moto E4 Plus Vibration Motor Replacement, Remove the midframe screws: étape 3, image 1 de 1
    • Remove the nineteen 3.2 mm long T3 screws securing the plastic midframe.
  4. Motorola Moto E4 Plus Vibration Motor Replacement, Release the midframe clips: étape 4, image 1 de 2 Motorola Moto E4 Plus Vibration Motor Replacement, Release the midframe clips: étape 4, image 2 de 2
    • The plastic midframe is still held in place with clips.
    • Insert the flat end of a spudger into the midframe seam at the bottom left corner of the phone (near the microphone hole).
    • Twist the spudger to release the plastic clip.
    • Repeat the process for the clip near the top right corner of the phone.
  5. Motorola Moto E4 Plus Vibration Motor Replacement, Remove the midframe: étape 5, image 1 de 2 Motorola Moto E4 Plus Vibration Motor Replacement, Remove the midframe: étape 5, image 2 de 2
    • Lift the bottom edge of the plastic midframe upwards until the clips along the top edge release.
    • Remove the plastic midframe.
    • To reattach the plastic midframe, line up the midframe to the phone and squeeze along the edges to engage the clips.
  6. Motorola Moto E4 Plus Vibration Motor Replacement, Disconnect the battery: étape 6, image 1 de 2 Motorola Moto E4 Plus Vibration Motor Replacement, Disconnect the battery: étape 6, image 2 de 2
    • Use the point of a spudger to pry up and disconnect the battery connector from its motherboard socket.
  7. Motorola Moto E4 Plus Vibration Motor Replacement, Disconnect the antenna: étape 7, image 1 de 2 Motorola Moto E4 Plus Vibration Motor Replacement, Disconnect the antenna: étape 7, image 2 de 2
    • Use the point of a spudger to pry up and disconnect the antenna cable from its daughterboard socket.
  8. Motorola Moto E4 Plus Vibration Motor Replacement, Disconnect the daughterboard connectors: étape 8, image 1 de 3 Motorola Moto E4 Plus Vibration Motor Replacement, Disconnect the daughterboard connectors: étape 8, image 2 de 3 Motorola Moto E4 Plus Vibration Motor Replacement, Disconnect the daughterboard connectors: étape 8, image 3 de 3
    • Use the point of a spudger to pry up and disconnect the interconnect cable from its daughterboard socket.
    • Pry up and disconnect the fingerprint sensor cable next to it from the daughterboard.
  9. Motorola Moto E4 Plus Vibration Motor Replacement, Remove the daughterboard screws: étape 9, image 1 de 1
    • Remove the two 3.2 mm long T3 screws securing the daughterboard.
  10. Motorola Moto E4 Plus Vibration Motor Replacement, Loosen the daughterboard: étape 10, image 1 de 2 Motorola Moto E4 Plus Vibration Motor Replacement, Loosen the daughterboard: étape 10, image 2 de 2
    • Insert the point of a spudger under the bottom right corner of the daughterboard and pry up to loosen the daughterboard.
  11. Motorola Moto E4 Plus Vibration Motor Replacement, Loosen the vibration motor: étape 11, image 1 de 2 Motorola Moto E4 Plus Vibration Motor Replacement, Loosen the vibration motor: étape 11, image 2 de 2
    • Insert the point of a spudger underneath the vibration motor and pry upwards to loosen it.
  12. Motorola Moto E4 Plus Vibration Motor Replacement, Remove the daughterboard: étape 12, image 1 de 2 Motorola Moto E4 Plus Vibration Motor Replacement, Remove the daughterboard: étape 12, image 2 de 2
    • Grasp the daughterboard by the edges and lift it out of its recess.
    • Remove the daughterboard. The vibration motor will be attached to it.
  13. Motorola Moto E4 Plus Vibration Motor Replacement, Vibration Motor: étape 13, image 1 de 3 Motorola Moto E4 Plus Vibration Motor Replacement, Vibration Motor: étape 13, image 2 de 3 Motorola Moto E4 Plus Vibration Motor Replacement, Vibration Motor: étape 13, image 3 de 3
    • Do not pull the connector out by the cables. It snaps in place from the top.
    • Insert the flat edge of a spudger between the vibration motor wires and the daughterboard
    • Gently twist to pry the connector upwards out of its socket.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Moto E4 Plus Answers community for help.
Arthur Shi
Membre depuis le 01/03/18
252 678 Réputation
526 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
135 membres
16 816 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 2
Total : 495
