Introduction
Use this guide to remove or replace the Moto E4 vibrator.
Before you begin, download the Rescue and Smart Assistant app to backup your device and diagnose whether your problem is software or hardware related.
Ce dont vous avez besoin
Remove the plastic cover by gently prying it up from the notch at the bottom right corner of the phone.
With the phone face down, lift the battery up by the labeled tab and remove it from the device.
Remove the six 4mm screws from the bottom plastic cover with a Phillips driver bit.
Outil utilisé dans cette étape :Halberd Spudger$2.99
Lift the vibrator out of its slot using the Halberd Spudger hook.
Gently pull the vibrator upwards to remove the vibrator wires from the silver clasp holding the wires to the board.
Pull directly upwards to remove the vibrator from its connector.
