Aller au contenu principal
Motorola Moto E6 Charging Dock Replacement
Ce dont vous avez besoin
  1. Motorola Moto E6 Charging Dock Replacement, Back Cover: étape 1, image 1 de 2 Motorola Moto E6 Charging Dock Replacement, Back Cover: étape 1, image 2 de 2
    • Begin by prying open the bottom right of the device using the plastic opening tool.
    • Work your way around the edge of the device, slowly prying open the casing until it pops off.
  2. Motorola Moto E6 Charging Dock Replacement, Battery: étape 2, image 1 de 1
    • Use the opening tool on the divot located below the battery to pop it out.
  3. Motorola Moto E6 Charging Dock Replacement, Charging Dock: étape 3, image 1 de 1
    • Remove the seven 3.8 mm T4 screws on the piece located below the battery compartment.
  4. Motorola Moto E6 Charging Dock Replacement: étape 4, image 1 de 1
    • Begin prying off the bottom piece with the opening tools on the divot located at the bottom left.
    • Work your way around the piece until it pops off.
  5. Motorola Moto E6 Charging Dock Replacement: étape 5, image 1 de 1
    • Remove the press fit cable at the top of the charging dock with the plastic opening tool.
    • Remove the coaxial cable using the plastic opening tool.
  6. Motorola Moto E6 Charging Dock Replacement: étape 6, image 1 de 1
    • Remove the two 1.1 mm T4 Torx screws on the bottom right and top left sides of the charging dock.
    • Remove the charging dock by hand.
6 autres ont terminé cette réparation.
Matthew Zelten
Membre depuis le 01/23/20
471 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team S2-G3, White Winter 2020 Membre de l'équipe Cal Poly, Team S2-G3, White Winter 2020
CPSU-WHITE-W20S2G3
4 membres
10 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 6
30 derniers jours : 23
Total : 2,800
