Aller au contenu principal
Motorola Moto E6 Front Facing Camera Replacement
Ce dont vous avez besoin
  1. Motorola Moto E6 Front Facing Camera Replacement, Back Cover: étape 1, image 1 de 2 Motorola Moto E6 Front Facing Camera Replacement, Back Cover: étape 1, image 2 de 2
    • Begin by prying open the bottom right of the device using the plastic opening tool.
    • Work your way around the edge of the device, slowly prying open the casing until it pops off.
  2. Motorola Moto E6 Front Facing Camera Replacement, Battery: étape 2, image 1 de 1
    • Use the opening tool on the divot located below the battery to pop it out.
  3. Motorola Moto E6 Front Facing Camera Replacement, Motherboard: étape 3, image 1 de 1
    • Remove the eleven 3.8 mm T4 Torx screws located above the battery compartment.
  4. Motorola Moto E6 Front Facing Camera Replacement: étape 4, image 1 de 1
    • Use the plastic opening tools to pry open the piece located at the top of the device.
    • Start by prying open the side of the compartment and work your way towards the camera module, prying open the compartment as you go.
    • Pop off the piece above the battery compartment.
  5. Motorola Moto E6 Front Facing Camera Replacement: étape 5, image 1 de 1
    • Remove the two 1.1 mm T4 Torx screws from the bottom left and top right sides of the motherboard.
  6. Motorola Moto E6 Front Facing Camera Replacement: étape 6, image 1 de 1
    • Remove the two press fit cables at the bottom of the motherboard with the plastic opening tool.
    • Remove the coaxial cable using the plastic opening tool.
    • After removing the cables, remove the motherboard from the phone by hand.
  7. Motorola Moto E6 Front Facing Camera Replacement, Front Facing Camera: étape 7, image 1 de 1
    • Remove the press fit cable holding the camera on the back of the motherboard using the plastic opening tool.
  8. Motorola Moto E6 Front Facing Camera Replacement: étape 8, image 1 de 1
    • Peel off the adhesive sticker tape holding the front facing camera using tweezers and remove the camera from the phone.
Alex Fontes
Membre depuis le 01/23/20
130 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team S2-G3, White Winter 2020 Membre de l'équipe Cal Poly, Team S2-G3, White Winter 2020
CPSU-WHITE-W20S2G3
4 membres
10 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 4
Total : 356
