Introduction
The camera on the Motorola Moto E6 should be replaced if it is taking blurry pictures, the lens is scratched, or the lens is cut. Use this guide to replace the camera module on the Moto E6. The motherboard has to be taken out first because there are cables from the camera on the back of the motherboard.
Before you begin, download the Rescue and Smart Assistant app to backup your device and diagnose whether your problem is software or hardware related.
Ce dont vous avez besoin
Begin by prying open the bottom right of the device using the plastic opening tool.
Work your way around the edge of the device, slowly prying open the casing until it pops off.
Remove the eleven 3.8 mm T4 Torx screws located above the battery compartment.
Remove the press fit cable using the plastic opening tool, and remove the camera from the phone.
