Aller au contenu principal
Motorola Moto G Power (2020) Battery Replacement
Ce dont vous avez besoin
  1. Motorola Moto G Power (2020) Battery Replacement, Back Panel: étape 1, image 1 de 1
    • Place a suction cup on the back of the device.
    • Then open up the back of the device by sliding the opening pick into both sides of the phone.
    • Do not remove the back panel completely; you must disconnect the fingerprint sensor first.
  2. Motorola Moto G Power (2020) Battery Replacement: étape 2, image 1 de 1
    • Put pressure on the fingerprint sensor with your finger to detach it from the back panel.
    • You may have to use significant force to get the circular sensor off the panel.
  3. Motorola Moto G Power (2020) Battery Replacement: étape 3, image 1 de 1
    • Completely remove the back panel from the device.
  4. Motorola Moto G Power (2020) Battery Replacement, Fingerprint Sensor: étape 4, image 1 de 1
    • Using a Torx T3 screwdriver, remove nine 2.2 mm screws.
  5. Motorola Moto G Power (2020) Battery Replacement: étape 5, image 1 de 3 Motorola Moto G Power (2020) Battery Replacement: étape 5, image 2 de 3 Motorola Moto G Power (2020) Battery Replacement: étape 5, image 3 de 3
    • Use the spudger to gently lift the cover.
    • If needed, use the spudger's tip against a corner of the cover to help lift it.
    • Set the back cover aside.
    • DO NOT use excessive force when lifting up the back cover.
  6. Motorola Moto G Power (2020) Battery Replacement: étape 6, image 1 de 1
    • Carefully use the spudger to lift the sensor cable, disconnecting the fingerprint sensor from the motherboard.
    • WARNING: Handle the sensor cable with care; it can be easily damaged.
  7. Motorola Moto G Power (2020) Battery Replacement: étape 7, image 1 de 1
    • Carefully remove the fingerprint sensor from the device and set it aside.
    • Do not use excessive force when lifting the back cover or any other component.
  8. Motorola Moto G Power (2020) Battery Replacement, Protective tape: étape 8, image 1 de 1
    • If present, carefully remove the protective tape using a plastic spudger as shown, ensuring the delicate flex cable is not torn in the process.
    • Be careful to not puncture or bend the battery! If punctured, it could start a fire. This is why we recommend discharging your device below 20% before beginning any repairs. Combustion could potentially cause damage to the device and your skin/clothing.
  9. Motorola Moto G Power (2020) Battery Replacement, Disconnect the flex cable: étape 9, image 1 de 2 Motorola Moto G Power (2020) Battery Replacement, Disconnect the flex cable: étape 9, image 2 de 2
    Outil utilisé dans cette étape :
    J'achète
    • Use a plastic spudger or non-conductive tweezers to disconnect the battery cable from the motherboard.
    • Ensure the tweezers are not pointed or sharp. Be gentle to avoid tearing the flex cable. This could cause a short-circuit in the battery connector, or scratch and damage traces on the motherboard.
  10. Motorola Moto G Power (2020) Battery Replacement, Seperate the old battery from the frame: étape 10, image 1 de 2 Motorola Moto G Power (2020) Battery Replacement, Seperate the old battery from the frame: étape 10, image 2 de 2
    • Slide an opening pick under the battery and gently work it back and forth to separate the adhesive from the battery.
    • This adhesive is quite strong and will require careful attention to apply the correct amount of force to remove the battery without damaging it in the process. Be patient and take it slow.
  11. Motorola Moto G Power (2020) Battery Replacement, Out with the old, in with the new: étape 11, image 1 de 1
    • Remove the old battery and insert the replacement battery, connecting it to the motherboard.
    • (Optional) Two-sided tape can be used to secure the battery to the frame if the original adhesive isn't strong enough to keep the new battery in place also.
To reassemble your device, follow these instructions in reverse order, excluding the battery removal, of course.
5 autres ont terminé cette réparation.
Harry Jung
Membre depuis le 06/23/22
736 Réputation
4 tutoriels rédigés
Équipe
UC Santa Barbara, Team 1-1, Bator Summer 2022 Membre de l'équipe UC Santa Barbara, Team 1-1, Bator Summer 2022
UCSB-BATOR-SU22S1G1
1 membre
5 tutoriels rédigés
5 commentaires
THIS OS THE WRONG BATTERY!!!!! IT's ABOUT 1/4" TOO LONG!!! WTF?!?!?!
Tweedle - Réponse
You link to the 'replacement" battery all say it's for the G Power (2022) but the GUIDE AND MY PHONE ARE THE 2020!!!!!
Your link goes to the JK50 battery.... but my Motorola g Power (2020) uses a KZ50 !!!! - OM<G I NEED MY PHONE!!!! AND NOW I HAVE TO WAIT TO SEND IT BACK, GET THE REFUND, AND THEN WAIT FOR THEM TO SEND BACK THE RIGHT ONE?!?!?!? - As you can tell because I OWN A CHEAP P.O.S. phone I CANNOT AFFORD TO 'just buy another one" ARRGGHHH!!!!!
Oh and my finger print sensor even broke off too... I tried SOOOO HARD not to break the wire... but it moved less than a 1/2" away and had already split.....
DO NOT BUY THIS PHONE!!! - Now I have no fingerprint sensor, the phone is NO LONGER WATER PROOF, AND IT DOESN'T EVEN WORK RIGHT NOW!!!!! AAARRGGGGHHHHH!!!!!!!!!!!! :'(
Tweedle - Réponse
How hard would it be for phone manufacturers to create a back cover to access battery for replacement...but NO, they make it as difficult as possible so they can make money selling new phones and/or sell repair services.
Tony Kawon - Réponse
I was an LG phone customer for many years because they were the last ones selling smart phones with user replaceable batteries. When they quit making their phones like that I switched to Motorola because i do like them better overall
Cee64E -
I purchased my "not Motorola" KZ50 battery from an eBay seller, it was a drop-in replacement for the original battery. I did have to do my own "fold" for the flex cable, not a big deal. I used my own T3 screwdriver, the "free" tools included with the battery are worth what I paid for them.
Richard Ekblaw - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 7
7 derniers jours : 88
30 derniers jours : 361
Total : 7,293
