Aller au contenu principal
Motorola Moto G Power (2020) Fingerprint Sensor Replacement
  1. Motorola Moto G Power (2020) Fingerprint Sensor Replacement, Back Panel: étape 1, image 1 de 1
    • Place a suction cup on the back of the device.
    • Then open up the back of the device by sliding the opening pick into both sides of the phone.
    • Do not remove the back panel completely; you must disconnect the fingerprint sensor first.
  2. Motorola Moto G Power (2020) Fingerprint Sensor Replacement: étape 2, image 1 de 1
    • Put pressure on the fingerprint sensor with your finger to detach it from the back panel.
    • You may have to use significant force to get the circular sensor off the panel.
  3. Motorola Moto G Power (2020) Fingerprint Sensor Replacement: étape 3, image 1 de 1
    • Completely remove the back panel from the device.
  4. Motorola Moto G Power (2020) Fingerprint Sensor Replacement, Fingerprint Sensor: étape 4, image 1 de 1
    • Using a Torx T3 screwdriver, remove nine 2.2 mm screws.
  5. Motorola Moto G Power (2020) Fingerprint Sensor Replacement: étape 5, image 1 de 3 Motorola Moto G Power (2020) Fingerprint Sensor Replacement: étape 5, image 2 de 3 Motorola Moto G Power (2020) Fingerprint Sensor Replacement: étape 5, image 3 de 3
    • Use the spudger to gently lift the cover.
    • If needed, use the spudger's tip against a corner of the cover to help lift it.
    • Set the back cover aside.
    • DO NOT use excessive force when lifting up the back cover.
  6. Motorola Moto G Power (2020) Fingerprint Sensor Replacement: étape 6, image 1 de 1
    • Carefully use the spudger to lift the sensor cable, disconnecting the fingerprint sensor from the motherboard.
    • WARNING: Handle the sensor cable with care; it can be easily damaged.
  7. Motorola Moto G Power (2020) Fingerprint Sensor Replacement: étape 7, image 1 de 1
    • Carefully remove the fingerprint sensor from the device and set it aside.
    • Do not use excessive force when lifting the back cover or any other component.
Harry Jung
Membre depuis le 06/23/22
736 Réputation
4 tutoriels rédigés
Équipe
UC Santa Barbara, Team 1-1, Bator Summer 2022 Membre de l'équipe UC Santa Barbara, Team 1-1, Bator Summer 2022
UCSB-BATOR-SU22S1G1
1 membre
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 5
30 derniers jours : 37
Total : 697
