Aller au contenu principal
Motorola Moto G Stylus 4G (2023) Charging Port Replacement
Ce dont vous avez besoin
  1. Motorola Moto G Stylus 4G (2023) Charging Port Replacement, Battery: étape 1, image 1 de 2 Motorola Moto G Stylus 4G (2023) Charging Port Replacement, Battery: étape 1, image 2 de 2
    • Insert an opening pick under the edge of the case and slide it around the edges.
    • Separate the back panel from the rest of the phone.
  2. Motorola Moto G Stylus 4G (2023) Charging Port Replacement: étape 2, image 1 de 1
    • Remove the seven 4 mm screws from the phone’s top with a Torx T5 screwdriver.
  3. Motorola Moto G Stylus 4G (2023) Charging Port Replacement: étape 3, image 1 de 2 Motorola Moto G Stylus 4G (2023) Charging Port Replacement: étape 3, image 2 de 2
    • Use the opening pick along the edges to separate the camera lens glass from the board.
  4. Motorola Moto G Stylus 4G (2023) Charging Port Replacement: étape 4, image 1 de 1
    • Remove three 4 mm screws with a Torx T5 screwdriver.
  5. Motorola Moto G Stylus 4G (2023) Charging Port Replacement: étape 5, image 1 de 1
    • Pry off the top perimeter with an ESD-safe spudger and set it aside.
  6. Motorola Moto G Stylus 4G (2023) Charging Port Replacement: étape 6, image 1 de 2 Motorola Moto G Stylus 4G (2023) Charging Port Replacement: étape 6, image 2 de 2
    • Pull the black tab off of the battery gently with your hand.
  7. Motorola Moto G Stylus 4G (2023) Charging Port Replacement: étape 7, image 1 de 2 Motorola Moto G Stylus 4G (2023) Charging Port Replacement: étape 7, image 2 de 2
    • Disconnect the four cables by inserting the opening pick beneath the edge of each.
  8. Motorola Moto G Stylus 4G (2023) Charging Port Replacement: étape 8, image 1 de 2 Motorola Moto G Stylus 4G (2023) Charging Port Replacement: étape 8, image 2 de 2
    • Together with the opening pick and an ESD-safe spudger, remove the old battery.
  9. Motorola Moto G Stylus 4G (2023) Charging Port Replacement, Ringer Speaker: étape 9, image 1 de 1
    • Remove seven 4 mm screws with the T5 Torx screwdriver.
  10. Motorola Moto G Stylus 4G (2023) Charging Port Replacement: étape 10, image 1 de 2 Motorola Moto G Stylus 4G (2023) Charging Port Replacement: étape 10, image 2 de 2
    • Remove the speaker using an ESD-safe spudger.
  11. Motorola Moto G Stylus 4G (2023) Charging Port Replacement, Charging Port: étape 11, image 1 de 1
    • Unplug the two antenna heads and main ribbon connector cable from the charging port board.
  12. Motorola Moto G Stylus 4G (2023) Charging Port Replacement: étape 12, image 1 de 1
    • Pull the faulty charging port from the device body.
Camille Holley
Membre depuis le 02/14/24
570 Réputation
5 tutoriels rédigés
Équipe
University of Memphis, Team 3-2, Sneed Spring 2024 Membre de l'équipe University of Memphis, Team 3-2, Sneed Spring 2024
UM-SNEED-S24S3G2
4 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 3
30 derniers jours : 15
Total : 65
