Aller au contenu principal
Motorola Moto G Stylus 4G (2023) Screen Replacement
Ce dont vous avez besoin
  1. Motorola Moto G Stylus 4G (2023) Screen Replacement, Battery: étape 1, image 1 de 2 Motorola Moto G Stylus 4G (2023) Screen Replacement, Battery: étape 1, image 2 de 2
    • Insert an opening pick under the edge of the case and slide it around the edges.
    • Separate the back panel from the rest of the phone.
  2. Motorola Moto G Stylus 4G (2023) Screen Replacement: étape 2, image 1 de 1
    • Remove the seven 4 mm screws from the phone’s top with a Torx T5 screwdriver.
  3. Motorola Moto G Stylus 4G (2023) Screen Replacement: étape 3, image 1 de 2 Motorola Moto G Stylus 4G (2023) Screen Replacement: étape 3, image 2 de 2
    • Use the opening pick along the edges to separate the camera lens glass from the board.
  4. Motorola Moto G Stylus 4G (2023) Screen Replacement: étape 4, image 1 de 1
    • Remove three 4 mm screws with a Torx T5 screwdriver.
  5. Motorola Moto G Stylus 4G (2023) Screen Replacement: étape 5, image 1 de 1
    • Pry off the top perimeter with an ESD-safe spudger and set it aside.
  6. Motorola Moto G Stylus 4G (2023) Screen Replacement: étape 6, image 1 de 2 Motorola Moto G Stylus 4G (2023) Screen Replacement: étape 6, image 2 de 2
    • Pull the black tab off of the battery gently with your hand.
  7. Motorola Moto G Stylus 4G (2023) Screen Replacement: étape 7, image 1 de 2 Motorola Moto G Stylus 4G (2023) Screen Replacement: étape 7, image 2 de 2
    • Disconnect the four cables by inserting the opening pick beneath the edge of each.
  8. Motorola Moto G Stylus 4G (2023) Screen Replacement: étape 8, image 1 de 2 Motorola Moto G Stylus 4G (2023) Screen Replacement: étape 8, image 2 de 2
    • Together with the opening pick and an ESD-safe spudger, remove the old battery.
  9. Motorola Moto G Stylus 4G (2023) Screen Replacement, Screen: étape 9, image 1 de 1
    • Apply heat using a heat gun to soften the adhesive around the edges of the screen.
    • Avoid overheating to prevent damage to the device.
  10. Motorola Moto G Stylus 4G (2023) Screen Replacement: étape 10, image 1 de 2 Motorola Moto G Stylus 4G (2023) Screen Replacement: étape 10, image 2 de 2
    • Insert a Jimmy into the crevice between the screen and the rest of the phone.
    • Work around the edges to gently pry the screen away from the phone.
    • Be careful to avoid glass fragments from the broken screen.
  11. Motorola Moto G Stylus 4G (2023) Screen Replacement: étape 11, image 1 de 1
    • Use a spudger to disconnect the screen connectors from the motherboard.
    • Remove any screws that are holding the screen in place.
  12. Motorola Moto G Stylus 4G (2023) Screen Replacement: étape 12, image 1 de 1
    • Remove the screen from the phone.
    • Clean the frame of any adhesive residue or glass shards.
    • Align the new screen to check its fit to the frame. Place the new screen with new adhesive.
Camille Holley
Membre depuis le 02/14/24
570 Réputation
5 tutoriels rédigés
Équipe
University of Memphis, Team 3-2, Sneed Spring 2024 Membre de l'équipe University of Memphis, Team 3-2, Sneed Spring 2024
UM-SNEED-S24S3G2
4 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 11
7 derniers jours : 36
30 derniers jours : 89
Total : 158
