Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Motorola Moto G XT1034 Back Case and Battery Cover Disassembly
Ce dont vous avez besoin
    1. Motorola Moto G XT1034 Back Case and Battery Cover Disassembly, Rear Panel: étape 1, image 1 de 3 Motorola Moto G XT1034 Back Case and Battery Cover Disassembly, Rear Panel: étape 1, image 2 de 3 Motorola Moto G XT1034 Back Case and Battery Cover Disassembly, Rear Panel: étape 1, image 3 de 3
      • Before you start following any of the steps of this guide, completely turn the device off.
      • Take the plastic back cover off by either using a plastic Pry tool or simply using your hands. Start from the bottom by the charging port
      Demander à FixBot
      Ajouter un commentaire
    2. Motorola Moto G XT1034 Back Case and Battery Cover Disassembly, Removing the Screws: étape 2, image 1 de 1
      • Unscrew the 3.5mm screws, total of 14, located on the back protective cover by using a T5 Torx screwdriver.
      Demander à FixBot
    3. Motorola Moto G XT1034 Back Case and Battery Cover Disassembly, Removing the Battery Cover: étape 3, image 1 de 2 Motorola Moto G XT1034 Back Case and Battery Cover Disassembly, Removing the Battery Cover: étape 3, image 2 de 2
      • Use a plastic opening tool to remove the protective cover.
      • Carefully work the plastic tool around all the edges of the phone.
      • The protective cover holds the Volume and the Home buttons which might fall off the assembly when the cover is removed.
      Demander à FixBot
7 autres ont terminé cette réparation.
Radostin Lobodov
Membre depuis le 10/16/14
2 946 Réputation
6 tutoriels rédigés
Équipe
UMass Dartmouth, Team 5-7, Vijaybhaskar Fall 2014 Membre de l'équipe UMass Dartmouth, Team 5-7, Vijaybhaskar Fall 2014
UMASSD-VIJAYBHASKAR-F14S5G7
3 membres
72 tutoriels rédigés
1 commentaire de tutoriel
tela ficou preta depois da queda
Guess Get - Réponse Partager
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 6
30 derniers jours : 32
Total : 2,046
