Introduction
Click here for an updated version of this guide. The version you are viewing is retained for historical purposes.
In this guide we will be removing and replacing the motherboard, which is the main source for all the other guides.
Ce dont vous avez besoin
Use the plastic opening tool to open the back cover as shown in the photo.
Apply the plastic opening tool on the edge of the screen near the front camera.
After creating enough space, allow the opening tool to be inserted on the side of the phone.
Create another space on the other side of the screen.
Leave the opening tool inserted.
Carefully apply the larger plastic opening tool by sliding it through the longer edge of the screen.
A strip will be attached to the motherboard as shown.
Using tweezers, carefully detach the strip from the motherboard.
That strip is the LCD display assembly flex cable, and it is attached to the motherboard via a ZIF connector. Using tweezers or a spudger, the plastic latch (which is on the side nearest the edge of the phone) must be gently lifted up away from the phone’s edge. Only then can the flex cable be safely (and carefully) removed.
If the repairer attempts to pull the flex cable out of its connector without first opening the latch, either the latch or the flex cable itself is likely to break, greatly complicating the repair.
With a T4 screwdriver, remove the10 "yellow" 2mm screws and 4 "black" 2mm screws.
3 autres ont terminé cette réparation.
Un commentaire
i broke my battery connectig port where we plug in the battery. What should i do?
PLZ answer
