Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Motorola Moto G4 Play Screen Replacement
Ce dont vous avez besoin
  1. Motorola Moto G4 Play Screen Replacement, Battery: étape 1, image 1 de 3 Motorola Moto G4 Play Screen Replacement, Battery: étape 1, image 2 de 3 Motorola Moto G4 Play Screen Replacement, Battery: étape 1, image 3 de 3
    • Open case with a plastic opening tool that has the same size as the divot located at the bottom left of the phone. If you don’t have an opening tool, use your finger nails.
    Demander à FixBot
    Ajouter un commentaire
  2. Motorola Moto G4 Play Screen Replacement: étape 2, image 1 de 3 Motorola Moto G4 Play Screen Replacement: étape 2, image 2 de 3 Motorola Moto G4 Play Screen Replacement: étape 2, image 3 de 3
    • Lift the case by the nearest corner to the divot and remove it from the phone.
    Demander à FixBot
  3. Motorola Moto G4 Play Screen Replacement: étape 3, image 1 de 3 Motorola Moto G4 Play Screen Replacement: étape 3, image 2 de 3 Motorola Moto G4 Play Screen Replacement: étape 3, image 3 de 3
    • Place the plastic opening tool into the notch located at the bottom of the battery compartment, and lift upwards. If you don’t have an opening tool, use your finger nails.
    • Remove battery from your phone.
    Demander à FixBot
  4. Motorola Moto G4 Play Screen Replacement, Midframe: étape 4, image 1 de 3 Motorola Moto G4 Play Screen Replacement, Midframe: étape 4, image 2 de 3 Motorola Moto G4 Play Screen Replacement, Midframe: étape 4, image 3 de 3
    • Remove any SIM card and/or memory card present using your hand.
    Demander à FixBot
  5. Motorola Moto G4 Play Screen Replacement: étape 5, image 1 de 2 Motorola Moto G4 Play Screen Replacement: étape 5, image 2 de 2
    Outil utilisé dans cette étape :
    • Remove the small silicon cover at the bottom right of the camera using tweezers.
    Demander à FixBot
  6. Motorola Moto G4 Play Screen Replacement: étape 6, image 1 de 1
    • Remove the sixteen (16) 3mm Phillips PH000 screws securing the midframe.
    • Some phones have two shorter screws, one on each side of the battery (double marked with orange circles at left). If your device has these shorter screws, make sure they go back in their original holes.
    Demander à FixBot
  7. Motorola Moto G4 Play Screen Replacement: étape 7, image 1 de 3 Motorola Moto G4 Play Screen Replacement: étape 7, image 2 de 3 Motorola Moto G4 Play Screen Replacement: étape 7, image 3 de 3
    • Remove the back panel assembly with your hands.
    Demander à FixBot
  8. Motorola Moto G4 Play Screen Replacement, Rear Camera: étape 8, image 1 de 3 Motorola Moto G4 Play Screen Replacement, Rear Camera: étape 8, image 2 de 3 Motorola Moto G4 Play Screen Replacement, Rear Camera: étape 8, image 3 de 3
    • Use the flat end of a spudger to disconnect the rear-facing camera connector from its socket on the mother board.
    Demander à FixBot
  9. Motorola Moto G4 Play Screen Replacement: étape 9, image 1 de 1
    • After detaching the connector, carefully remove the camera using tweezers. If you don't have tweezers, use your hands.
    Demander à FixBot
  10. Motorola Moto G4 Play Screen Replacement, Charging Port: étape 10, image 1 de 2 Motorola Moto G4 Play Screen Replacement, Charging Port: étape 10, image 2 de 2
    • Use tweezers to pop up the antenna wire.
    Demander à FixBot
  11. Motorola Moto G4 Play Screen Replacement: étape 11, image 1 de 2 Motorola Moto G4 Play Screen Replacement: étape 11, image 2 de 2
    • Use the flat end of a spudger to pry up on the connector at the bottom of the battery space.
    Demander à FixBot
  12. Motorola Moto G4 Play Screen Replacement: étape 12, image 1 de 1
    • Remove the two (2) 3mm Phillips PH000 screws securing the charging port.
    Demander à FixBot
  13. Motorola Moto G4 Play Screen Replacement: étape 13, image 1 de 3 Motorola Moto G4 Play Screen Replacement: étape 13, image 2 de 3 Motorola Moto G4 Play Screen Replacement: étape 13, image 3 de 3
    • Insert the tweezers under the vibrator and gently lift up the whole part.
    Demander à FixBot
  14. Motorola Moto G4 Play Screen Replacement: étape 14, image 1 de 3 Motorola Moto G4 Play Screen Replacement: étape 14, image 2 de 3 Motorola Moto G4 Play Screen Replacement: étape 14, image 3 de 3
    • Pop up on the vibrator's connector to separate it from the charging port.
    Demander à FixBot
  15. Motorola Moto G4 Play Screen Replacement, Screen: étape 15, image 1 de 3 Motorola Moto G4 Play Screen Replacement, Screen: étape 15, image 2 de 3 Motorola Moto G4 Play Screen Replacement, Screen: étape 15, image 3 de 3
    • Using an opening tool, pry up one of the connectors to the left of where the sim card was located.
    Demander à FixBot
  16. Motorola Moto G4 Play Screen Replacement: étape 16, image 1 de 3 Motorola Moto G4 Play Screen Replacement: étape 16, image 2 de 3 Motorola Moto G4 Play Screen Replacement: étape 16, image 3 de 3
    • Pry up the next connector located right on top of the previous one.
    Demander à FixBot
  17. Motorola Moto G4 Play Screen Replacement: étape 17, image 1 de 3 Motorola Moto G4 Play Screen Replacement: étape 17, image 2 de 3 Motorola Moto G4 Play Screen Replacement: étape 17, image 3 de 3
    • Using the Phillips screwdriver, remove the screw that's found next to the speaker on the top left of the phone.
    Demander à FixBot
  18. Motorola Moto G4 Play Screen Replacement: étape 18, image 1 de 3 Motorola Moto G4 Play Screen Replacement: étape 18, image 2 de 3 Motorola Moto G4 Play Screen Replacement: étape 18, image 3 de 3
    • Using the plastic opening tool, carefully pry up the motherboard.
    Demander à FixBot
  19. Motorola Moto G4 Play Screen Replacement: étape 19, image 1 de 2 Motorola Moto G4 Play Screen Replacement: étape 19, image 2 de 2
    • Pull up the cable that connects the motherboard and the charging port.
    • It's on the side that's closer to the motherboard, you might need to push the cable down first, and then pull it up.
    Demander à FixBot
  20. Motorola Moto G4 Play Screen Replacement: étape 20, image 1 de 3 Motorola Moto G4 Play Screen Replacement: étape 20, image 2 de 3 Motorola Moto G4 Play Screen Replacement: étape 20, image 3 de 3
    • Pry up the frontal speaker with a plastic opening tool.
    Demander à FixBot
  21. Motorola Moto G4 Play Screen Replacement: étape 21, image 1 de 3 Motorola Moto G4 Play Screen Replacement: étape 21, image 2 de 3 Motorola Moto G4 Play Screen Replacement: étape 21, image 3 de 3
    • Peel the black tape up with a plastic opening tool and or your fingers.
    Demander à FixBot
  22. Motorola Moto G4 Play Screen Replacement: étape 22, image 1 de 3 Motorola Moto G4 Play Screen Replacement: étape 22, image 2 de 3 Motorola Moto G4 Play Screen Replacement: étape 22, image 3 de 3
    • Peel the flexible black cable using a plastic opening tool and or your fingers.
    Demander à FixBot
  23. Motorola Moto G4 Play Screen Replacement: étape 23, image 1 de 3 Motorola Moto G4 Play Screen Replacement: étape 23, image 2 de 3 Motorola Moto G4 Play Screen Replacement: étape 23, image 3 de 3
    • Peel up the small tape that's connected to the screen with a plastic opening tool.
    Demander à FixBot
  24. Motorola Moto G4 Play Screen Replacement: étape 24, image 1 de 2 Motorola Moto G4 Play Screen Replacement: étape 24, image 2 de 2
    • Place an iOpener on the edges to soften the screen adhesive.
    Demander à FixBot
  25. Motorola Moto G4 Play Screen Replacement: étape 25, image 1 de 3 Motorola Moto G4 Play Screen Replacement: étape 25, image 2 de 3 Motorola Moto G4 Play Screen Replacement: étape 25, image 3 de 3
    Plastic Cards
    $2.99
    • Insert the Jimmy knife through the edge.
    • Place a plastic card so that the adhesive doesn't stick back again.
    • Go around the edges of the device with the Jimmy knife until all the adhesive has been removed.
    Demander à FixBot
  26. Motorola Moto G4 Play Screen Replacement: étape 26, image 1 de 3 Motorola Moto G4 Play Screen Replacement: étape 26, image 2 de 3 Motorola Moto G4 Play Screen Replacement: étape 26, image 3 de 3
    • Pull up on the LCD screen with your hands and remove it.
    Demander à FixBot
10 autres ont terminé cette réparation.
Yordan Gil
Membre depuis le 02/14/18
447 Réputation
1 tutoriel rédigé
Équipe
USF Tampa, Team S17-G4, Boczar Spring 2018 Membre de l'équipe USF Tampa, Team S17-G4, Boczar Spring 2018
USFT-BOCZAR-S18S17G4
4 membres
22 tutoriels rédigés
4 commentaires de tutoriel
The phone I just tried to fix had two digitizer connectors just like the one in this procedure, but all the replacement parts I can find on ebay and aliexpress etc. which claim to be for XT1601 - XT1609 have just a single connector. Any thoughts about why that would be?
jrhooker - Réponse Partager
The smaller one is from the power and Volume buttons and needs tobe transfered to the new display if you bought one with Frame (which makes it much easier)
Marko Käppler - Réponse Partager
I had to figure out that out myself. Yes, you will need to transfer the connector from the old frame to the new frame. I should also add, the frame I got had no buttons, so I had to get them from the old phone.
Joshua Rieth - Réponse Partager
Good guide though I could not see the purpose of removing items 20, 21 & 22
pauldmallett - Réponse Partager
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 15
30 derniers jours : 71
Total : 5,635
