Introduction
This guide will help with the replacement of a broken or faulty motherboard.
Before you begin, download the Software Fix app to backup your device and diagnose whether your problem is software or hardware related.
Ce dont vous avez besoin
Insert your fingernail or the flat end of a spudger into the notch on the bottom edge of the phone near the charging port.
Pry with your fingernail or twist the spudger to release the back cover from the phone.
Insert your fingernail or the flat end of the spudger into the notch below the battery.
Pry with your fingernail or spudger until you free the battery from its recess.
Remove the two 4mm screws shown in the picture using a Phillips #00 screwdriver.
11 autres ont terminé cette réparation.
2 commentaires de tutoriel
is a xt1670 logic board compatible with a xt1671 phone?
While disassembling I accidentally broke off one of the antenna "pins" (the one under the audio jack). I'll try to solder it on again, but in case I cannot, you think it will affect its proper operation too much? I cannot test it right now as I am waiting a replacement side buttons board.
