Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Introduction
The battery is a delicate and critical component of a cell phone, and great care should be taken when replacing it. The Motorola Moto X 2nd generation phone battery can be replaced without any specialized skills and only a few standard maintenance tools. Make sure to power off the phone completely and disconnect from all cables. You should always back up your phone data when replacing a critical component to avoid any losses due to accidental damage. Take additional care if the battery is swollen..
  1. Remove the SIM card tray by inserting the SIM card eject tool into the small hole on the tray. Remove the SIM card tray by inserting the SIM card eject tool into the small hole on the tray. Remove the SIM card tray by inserting the SIM card eject tool into the small hole on the tray.
    • Remove the SIM card tray by inserting the SIM card eject tool into the small hole on the tray.
  2. Insert a SIM eject tool into the SIM tray slot, and through a small hole in the mid frame. Push the SIM eject tool through the hole and against the back cover to lift the cover slightly. Insert an opening pick into the gap created with the SIM eject tool, and slide the pick around the edge of the cover to cut the cover's adhesive.
    • Insert a SIM eject tool into the SIM tray slot, and through a small hole in the mid frame.
    • Push the SIM eject tool through the hole and against the back cover to lift the cover slightly.
    • Insert an opening pick into the gap created with the SIM eject tool, and slide the pick around the edge of the cover to cut the cover's adhesive.
    • Cut carefully near the volume buttons, to avoid damaging the delicate ribbon cables in that area under the cover.
    • Remove back cover.
  3. Remove the rubber covers from the two connector pieces indicated in the photo Remove the rubber covers from the two connector pieces indicated in the photo
    • Remove the rubber covers from the two connector pieces indicated in the photo
  4. Use the spudger to release the connectors from under the covers. Use the spudger to release the connectors from under the covers.
    • Use the spudger to release the connectors from under the covers.
  5. Remove the screws and then remove the middle housing from front assembly. Remove the screws and then remove the middle housing from front assembly.
    • Remove the screws and then remove the middle housing from front assembly.
  6. Remove the logo, as the flex cable under the logo is fastened to the back of the battery. This can be done by removing the three surrounding  screws, and then prying off the structure that encapsulates the logo. Remove the logo, as the flex cable under the logo is fastened to the back of the battery. This can be done by removing the three surrounding  screws, and then prying off the structure that encapsulates the logo. Remove the logo, as the flex cable under the logo is fastened to the back of the battery. This can be done by removing the three surrounding  screws, and then prying off the structure that encapsulates the logo.
    • Remove the logo, as the flex cable under the logo is fastened to the back of the battery. This can be done by removing the three surrounding screws, and then prying off the structure that encapsulates the logo.
  7. Use the flat end of a spudger to gently pry up the ribbon cable in the two places where it is adhered to the battery. Use the flat end of a spudger to gently pry up the ribbon cable in the two places where it is adhered to the battery.
    • Use the flat end of a spudger to gently pry up the ribbon cable in the two places where it is adhered to the battery.
  8. Lift one of the two battery adhesive tabs and pull firmly and steadily toward the bottom edge of the phone, until the adhesive strip slides all the way out from between the battery and the phone. Repeat for the other adhesive tab. Remove the battery.
    • Lift one of the two battery adhesive tabs and pull firmly and steadily toward the bottom edge of the phone, until the adhesive strip slides all the way out from between the battery and the phone.
    • Repeat for the other adhesive tab.
    • Remove the battery.
    • If the adhesive strips do not fully come out you will need to pry it out from the other side, but be VERY careful as the NFC coil is under the battery and can be ripped easily.
After completing this guide, calibrate your newly-installed battery.
51 autre(s) ont terminé cette réparation.
Sophia
Membre depuis le 25/03/2014
43 297 Réputation
62 tutoriels rédigés
37 commentaires
Are you friggin' kidding me. Why would Motorola make a major project out of simply removing a battery. Definately needs to be simplified. It'seems like doing friggin' surgery on a phone.
tspeanut122 - Réponse
Too funny! hahahha
Pamela Orjuela -
I'd call this battery replacement requirement 'built in obsolescence'! There's no way I'd attempt this. I'd rather buy a new phone. Then again, that's probably why it's so complicated...
Ben Miller - Réponse
LOL Obviously you've never replaced a laptop motherboard ;)
nightopz - Réponse
How do you repeat the steps in reverse such that you replace the adhesive holding the battery in place? Does a new battery come with the adhesive?
Richard Glendinning - Réponse
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 7
7 derniers jours : 24
30 derniers jours : 93
Total : 75,598
