Aller au contenu principal
Motorola Moto X Motherboard Replacement
Ce dont vous avez besoin
  1. Motorola Moto X Motherboard Replacement, SIM Card: étape 1, image 1 de 3 Motorola Moto X Motherboard Replacement, SIM Card: étape 1, image 2 de 3 Motorola Moto X Motherboard Replacement, SIM Card: étape 1, image 3 de 3
    • Insert the SIM card eject tool into the hole in the side of the SIM card tray and push to eject the tray.
    • Remove the SIM card tray.
    • If the SIM card does not fall free from the tray on its own, simply remove it with your fingers.
  2. Motorola Moto X Motherboard Replacement, Back Cover Assembly: étape 2, image 1 de 3 Motorola Moto X Motherboard Replacement, Back Cover Assembly: étape 2, image 2 de 3 Motorola Moto X Motherboard Replacement, Back Cover Assembly: étape 2, image 3 de 3
    • In the following steps you will be releasing the clips holding the phone's cases together. However, the back case is also secured with an adhesive pad. After separating the clips you will use an iOpener to allow the case to fully open. Do not attempt to fully open the phone before loosening the adhesive.
    • Insert a plastic opening tool into the seam between the front and rear covers near the SIM card slot.
    • Slide the plastic opening tool along the seam toward the upper corner.
  3. Motorola Moto X Motherboard Replacement: étape 3, image 1 de 2 Motorola Moto X Motherboard Replacement: étape 3, image 2 de 2
    • Carefully slide the plastic opening tool around the corner, freeing it from clips.
  4. Motorola Moto X Motherboard Replacement: étape 4, image 1 de 2 Motorola Moto X Motherboard Replacement: étape 4, image 2 de 2
    • Pry around the top right corner of the phone between the two covers.
  5. Motorola Moto X Motherboard Replacement: étape 5, image 1 de 3 Motorola Moto X Motherboard Replacement: étape 5, image 2 de 3 Motorola Moto X Motherboard Replacement: étape 5, image 3 de 3
    • Run the opening tool along the seam around all four sides, separating the remaining clips holding the cover on.
    • The plastic on the front cover is thinner near the buttons, and the buttons may move around. Go slowly to avoid damaging the buttons or the front cover.
    • Do not push the opening tool deep into phone, or you may damage internal components.
  6. Motorola Moto X Motherboard Replacement: étape 6, image 1 de 1
    • Heat an iOpener and lay it over the phone for approximately 90 seconds to loosen the adhesive securing the back cover.
  7. Motorola Moto X Motherboard Replacement: étape 7, image 1 de 3 Motorola Moto X Motherboard Replacement: étape 7, image 2 de 3 Motorola Moto X Motherboard Replacement: étape 7, image 3 de 3
    • Starting from the SIM slot side, carefully peel the back cover off of the phone.
    • The back cover is very flexible, but you don't want to damage any internal components by being too hasty.
    • There is a chance that the NFC coil may remain stubbornly adhered to the back cover. If that's the case, stop peeling the cover and reapply a heated iOpener to the back cover.
    • Do not separate the back cover entirely; it is still connected to the phone by the camera flash cable.
    • The flash cable is attached on the power/volume button side of the phone.
  8. Motorola Moto X Motherboard Replacement: étape 8, image 1 de 1
    • Gently set the back cover down in a way that exposes the camera flash cable connector, but does not put strain on it.
  9. Motorola Moto X Motherboard Replacement: étape 9, image 1 de 3 Motorola Moto X Motherboard Replacement: étape 9, image 2 de 3 Motorola Moto X Motherboard Replacement: étape 9, image 3 de 3
    • Use the tip of a spudger to flip up the retaining flap on the flash cable ZIF connector.
    • Be sure to pry only on the flap itself, not on the connector.
    • Pull the flash cable straight out of its socket.
  10. Motorola Moto X Motherboard Replacement: étape 10, image 1 de 1
    • Separate the back cover from the phone.
  11. Motorola Moto X Motherboard Replacement, Lower Antenna Assembly: étape 11, image 1 de 1
    • Remove the four 3 mm T3 Torx screws securing the lower antenna assembly to the phone.
  12. Motorola Moto X Motherboard Replacement: étape 12, image 1 de 3 Motorola Moto X Motherboard Replacement: étape 12, image 2 de 3 Motorola Moto X Motherboard Replacement: étape 12, image 3 de 3
    • Use the flat end of a spudger to pry up the lower antenna assembly and free it from the phone.
    • Remove the antenna assembly.
  13. Motorola Moto X Motherboard Replacement, Battery: étape 13, image 1 de 3 Motorola Moto X Motherboard Replacement, Battery: étape 13, image 2 de 3 Motorola Moto X Motherboard Replacement, Battery: étape 13, image 3 de 3
    • Insert the tip of a spudger under the battery cable near the connector to lift it straight up from its socket.
    • Use the flat end of a spudger to disconnect the NFC antenna cable connector.
  14. Motorola Moto X Motherboard Replacement: étape 14, image 1 de 3 Motorola Moto X Motherboard Replacement: étape 14, image 2 de 3 Motorola Moto X Motherboard Replacement: étape 14, image 3 de 3
    • Use the tip of a spudger to flip up the ZIF retaining flap from the button assembly cable connector.
    • Slide the tip of the spudger under the button assembly cable near the connector to pull the cable straight out of its socket.
  15. Motorola Moto X Motherboard Replacement: étape 15, image 1 de 2 Motorola Moto X Motherboard Replacement: étape 15, image 2 de 2
    • Insert the flat end of a spudger under the interconnect cable to free it from the adhesive holding it to the battery.
  16. Motorola Moto X Motherboard Replacement: étape 16, image 1 de 2 Motorola Moto X Motherboard Replacement: étape 16, image 2 de 2
    • Use the flat end of a spudger to peel the adhesive pull-tab off the top of battery.
  17. Motorola Moto X Motherboard Replacement: étape 17, image 1 de 3 Motorola Moto X Motherboard Replacement: étape 17, image 2 de 3 Motorola Moto X Motherboard Replacement: étape 17, image 3 de 3
    Outil utilisé dans cette étape :
    Tesa 61395 Tape
    $5.99
    J'achète
    • Use the adhesive pull-tab to lift the battery from its recess.
    • The battery is secured to the motherboard with mild adhesive. Peel slowly, and be careful not to bend or puncture the battery.
    • Remove the battery from the phone.
    • When reassembling your phone secure the battery with double-sided tape or pre-cut adhesive strips.
  18. Motorola Moto X Motherboard Replacement, Motherboard Assembly: étape 18, image 1 de 1
    • Remove the five 3 mm T3 Torx screws from the headphone jack/speaker assembly.
  19. Motorola Moto X Motherboard Replacement: étape 19, image 1 de 3 Motorola Moto X Motherboard Replacement: étape 19, image 2 de 3 Motorola Moto X Motherboard Replacement: étape 19, image 3 de 3
    • Insert a spudger under the panhandle of the headphone jack/speaker assembly and pry it up from its recess.
    • Remove the headphone jack/speaker assembly.
  20. Motorola Moto X Motherboard Replacement: étape 20, image 1 de 2 Motorola Moto X Motherboard Replacement: étape 20, image 2 de 2
    • Push the tip of a spudger under the microphone assembly clip to free it from the earpiece speaker.
    • If the assembly clip seems to be missing, check the speaker assembly that was removed from the previous step.
  21. Motorola Moto X Motherboard Replacement: étape 21, image 1 de 2 Motorola Moto X Motherboard Replacement: étape 21, image 2 de 2
    • Use the flat end of a spudger to free the microphone assembly cable connector.
    • Use tweezers to remove the microphone assembly.
  22. Motorola Moto X Motherboard Replacement: étape 22, image 1 de 2 Motorola Moto X Motherboard Replacement: étape 22, image 2 de 2
    • Disconnect the front-facing camera cable connector.
    • Remove the front-facing camera from its recess with a pair of tweezers.
  23. Motorola Moto X Motherboard Replacement: étape 23, image 1 de 1
    • Remove the final two 3 mm T3 Torx screws from the SIM slot bracket.
  24. Motorola Moto X Motherboard Replacement: étape 24, image 1 de 1
    • Remove the SIM slot bracket from the motherboard.
  25. Motorola Moto X Motherboard Replacement: étape 25, image 1 de 2 Motorola Moto X Motherboard Replacement: étape 25, image 2 de 2
    • Insert the flat end of a spudger under the motherboard above the button assembly cable, and pry it out of the phone.
    • Be careful not to snag any cables.
    • The buttons may pop out of their recesses; take care not to lose them.
  26. Motorola Moto X Motherboard Replacement: étape 26, image 1 de 2 Motorola Moto X Motherboard Replacement: étape 26, image 2 de 2
    • Gently lift the motherboard out of the phone, rotating it from the SIM slot edge of the phone.
    • Do not attempt to separate the motherboard entirely; it is still connected to the display by the display cable.
  27. Motorola Moto X Motherboard Replacement: étape 27, image 1 de 3 Motorola Moto X Motherboard Replacement: étape 27, image 2 de 3 Motorola Moto X Motherboard Replacement: étape 27, image 3 de 3
    • Lay the motherboard down to allow access to the display cable connector.
    • Use the flat end of a spudger to flip the retaining tab on the display cable ZIF connector.
    • Carefully pull the display cable out of its connector as you remove the motherboard from the display assembly.
  28. Motorola Moto X Motherboard Replacement, Motherboard: étape 28, image 1 de 2 Motorola Moto X Motherboard Replacement, Motherboard: étape 28, image 2 de 2
    • Use the flat end of a spudger to free the interconnect cable connector.
    • Remove the interconnect cable from the motherboard.
  29. Motorola Moto X Motherboard Replacement: étape 29, image 1 de 3 Motorola Moto X Motherboard Replacement: étape 29, image 2 de 3 Motorola Moto X Motherboard Replacement: étape 29, image 3 de 3
    • Use the flat end of a spudger to flip up the retaining tab on the front-facing camera ZIF cable connector.
    • Remove the front-facing camera from the motherboard.
8 autres ont terminé cette réparation.
Sam Goldheart
Membre depuis le 10/18/12
465 738 Réputation
538 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
135 membres
16 767 tutoriels rédigés
3 commentaires
Where i can find motherboard scheme?
evgenholkin - Réponse
Where is the Bluetooth/WiFi filter?
Mine doesn't work, I need to replace it. I'm from India.
What are the other alternatives for the filter? I mean, other filters that can be used (Replacement for the original one, ofcourse).
I've been using my Moto X (1st Gen) as an Mp3 player/Camera/Video Player. I don't want to continue using it this way. This smartphone is one of the best mankind has ever manufactured. Any help is much appreciated.
Thank you.
Email: amleakhilesh@gmail.com
Akhilesh Amle - Réponse
Where can I buy this motherboard?
Also where can I buy another back facing camera?
Brandon Sayareh - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 3
Total : 23,904
